C4 F45 adjustable shock swap help
Old Mar 6, 2003 | 01:31 AM
C5stein's Avatar
0C5stein
Former Vendor
Default C4 F45 adjustable shock swap help
I usually work on C5s and I have a customer that wants to take his "Active handling" and Cockpit adjustable shocks off and put my coil over adjustable shock setup on. How do I simulate to the computer that shocks are still there so the car will not go into reduced power mode.
Thanks for the help.
Old Mar 6, 2003 | 06:06 AM
GS Ragtop's Avatar
GS Ragtop
From: Michigan in the summer, Florida the rest of the time
St. Jude Donor '08-'09-'11
Default Re: C4 F45 adjustable shock swap help (C5stein)
Here's Jim Mason's writeup from the Tech Tips section of http://www.hashmarks.com:
#007 is equipped with F45 Real Time Damping (RTD). While RTD was a neat gimmick when I bought the car, reality is that the only time I moved the dial in the last 4 years was to switch from "Perf" to "Tour" when drag racing. The F45 RTD shocks were manufactured by Delphi. Unlike Bilstein who offers a rebuild service for the FX3 shocks ($55/shock), the Delphi units are "Throwaway". A review of the cost of replacing these shocks (~$600 was the best price I could find), indicated the gimmick was no longer very attractive. With that in mind, I settled on '90 Z51 Bilstein shocks. Having previously owned a '90 Z51 car, I somewhat knew what to expect relative to ride. The Z51 shocks combined with the F45 springs (same as the base suspension springs), provides a ride that's controlled in both rebound and compression, but not harsh. While not a "9/10s" solution like adjustable Koni's or a "100%" solution like coil-overs, it is a nice upgrade to a base suspension or F45 equipped car.
For those who still have the original shocks, I highly recommend checking them. Most likely they'll need replacement. A simple test is to remove one of the front shocks and see if you can compress it by hand. Two of mine had 0 rebound and the other two were easily compressed.
In order to avoid setting the "SERVICE RIDE CONTROL" (SRC) Malfunction Indicator Lamp (MIL), I snipped the connector ends from the old F45 shocks. I modified each connector to accept a 220 ohm resistor and then plugged them into the female connectors that are part of the chassis wiring harness at each corner. No MIL and a factory wiring appearance to all but the most astute observer :-) I did have a brief bout with confusion (some may say it's not brief [grin]). While checking the wiring modifications, I turned the key to "RUN" and got the SRC MIL (!). I pulled the SRC codes and found DTCs indicating out of range position sensors. After a moment of thought, I realized that the codes were set because I had yet to install the new shocks and the suspension was "sagging". I temporarily propped the suspension, turned the ignition key to "RUN" and the problem was solved.
Brad
[Modified by GS Ragtop, 6:07 AM 3/6/2003]
Old Mar 6, 2003 | 08:32 AM
96GS#007's Avatar
96GS#007
Default Re: C4 F45 adjustable shock swap help (GS Ragtop)
Here's Jim Mason's writeup from the Tech Tips section of http://www.hashmarks.com: Brad
:D
Old Mar 6, 2003 | 05:14 PM
C5stein's Avatar
0C5stein
Former Vendor
Default Re: C4 F45 adjustable shock swap help (96GS#007)
Hey you guys are the BOMB :thumbs:
so I use a 220 ohm resistor.
On the C5's they only need a 15 ohm.
Thanks for all the help.
If either on of you ever want to trade up to adjustable valved shocks or Adjustable valve/adjustable ride height shocks. Just shoot me an email and I'll hook you up.
I've applied to become a CF supporting vendor so I should be online soon.
Thanks again.
[Modified by C5stein, 2:15 PM 3/6/2003]
Old Mar 6, 2003 | 06:34 PM
96GS#007's Avatar
96GS#007
I appreciate the shock offer!
Regarding the resistor...I've been using the 220ohm since day I made the swap about a year ago :)
:cheers:
Old Mar 7, 2003 | 02:56 PM
NotSlo's Avatar
NotSlo
Elite Member
Cruise-In III Veteran
St. Jude Donor '09
I took mine out, replaced them with Bilstein Z51s and never jumped anything. Never have had a problem.
Old Mar 7, 2003 | 08:01 PM
Dan Parker '96's Avatar
Dan Parker '96
Default Re: C4 F45 adjustable shock swap help (NotSlo)
Same as above. Swapped to the Z51 Bilstein's with no codes.
Old Mar 11, 2003 | 05:45 AM
wake's Avatar
wake
Wow, I see lots of modifying, cutting, etc...
I just pulled the fuse in the ABS compartment and no SRC light since I changed the shocks about 2 years ago...
Old Mar 11, 2003 | 11:21 AM
96GS#007's Avatar
96GS#007
Default Re: C4 F45 adjustable shock swap help (wake)
As a test I pulled the fuse and my speedo display started flashing "SYS" and triggering nusiance codes in the CCM :(
The resistors cost cost me $0.50 and I simply inserted them into the open connector ends. Not cutting, no splicing, just a little electrical tape to hold them in place.
:cheers:
Old Mar 12, 2003 | 02:09 AM
wake's Avatar
wake
:cheers:
Hmmm, interesting...
I've never seen the SYS in my display, now I'm wondering why...
Old Mar 20, 2003 | 03:38 AM
NotSlo's Avatar
NotSlo
Elite Member
St. Jude Donor '09
Saturday I got the "service ride control message". Somehow the ride control switch got moved from the far right selection when I was cleaning. I moved it back and let the car sit for a while. The code cleared and never came back. Weird.
Old Mar 20, 2003 | 06:36 AM
Dan Parker '96
Hmmm. I'll have to try that. Come to think of it, my switch has never come off the PERF setting. A quick look at the owner's manual states that if the switch gets "in between" settings then it could trigger the "service ride control" light as well.
To C4 F45 adjustable shock swap help
