Any differences between dana 44 gears/rear ends between years?
Old Mar 6, 2003 | 08:21 AM
Dr. Evil's Avatar
Dr. Evil
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
Default Any differences between dana 44 gears/rear ends between years?
Would a gear set or ring and pinion from say, a mid late 80s C4 work in a later C4 as long as the 2 are both dana 44 (obviously)
Old Mar 7, 2003 | 01:37 AM
Dr. Evil's Avatar
Dr. Evil
CI-IV AutoX Champ
CI-IV Burnout Champ
Default Re: Any differences between dana 44 gears/rear ends between years? (Dr. Evil)
No one? :confused:
Old Mar 7, 2003 | 04:28 AM
SHiNoBi LT4's Avatar
SHiNoBi LT4
i believe they are the same throughout. Noone ever has mentioned any differences that i can remember. Only the trannys were changed (different torque ratings) but the diffs remained the same.
Old Mar 8, 2003 | 12:58 AM
CFI-EFI's Avatar
CFI-EFI
YES! Be sure to use the proper, diff (internal) case if a ratio change is involved. Good luck, and...
RACE ON!!!
To Any differences between dana 44 gears/rear ends between years?
