A/C (C68) Control head?
Old Mar 8, 2003 | 02:59 PM
R23HTC's Avatar
R23HTC
Default A/C (C68) Control head?
Okay. I've been having problems with the operation of this unit lately. It stores no codes and when it's warm out (above 40°) it works properly. If it's colder out, then my defrost won't work because the A/C won't come on. The A/C recurculate switch won't work as well. I'm wondering if anyone has an idea if I might be able to fix the controller; if anyone has had this problem and fixed it without buying a new control head? Possibly the curcuit board? Anything specific to look for?
Old Mar 8, 2003 | 04:25 PM
Tom Piper's Avatar
Tom Piper
Default Re: A/C (C68) Control head? (R94 LT 1)
Both R12 and R134a AC systems are designed with a pressure sensing switch to keep them from activating the compressor when the low-side pressure is below about 45 psi. Since the freon pressure in the system is directly proportional to the temperature, at 45 psi this equates to about 40 degrees F. So, the system is designed to keep the compressor turned off when the temperature is below 40 degrees F.
However, this should not affect the defrost controls -- when in defrost, the air should still come out at the base of the windshield.
Old Mar 8, 2003 | 04:43 PM
R23HTC's Avatar
R23HTC
Default Re: A/C (Tom Piper)
Okay. Maybe, that's it, I'm not sure. I'm thinking that would not keep the control panel from working properly. Maybe I'm wrong. (reason I posted the ?) I've had the car out on a 11° day in previous years and the controls still worked. Grant it I wouldn't want my A/C running (except for defrost on heat), but the control panel would still control it. At this point I'm almost certain it's the control panel itself, I'm just wondering if anyone has had a similar problem and fixed it without having to purchase a new controller?
Edit: additionally, if I do click the defrost switch when I'm having this "problem" I don't get any air at all as the fan won't every kick on. Since I know I have the problem, my solution up to this point is to first get in and see if the A/C recr. switch works. If it doesn't, then I don't fit the defrost switch. I just use floor heat and run the fan on 10 so that it fills the car with heat and keeps the windows from fogging up. (and me from freezing)
[Modified by R94 LT 1, 3:47 PM 3/8/2003]
To A/C (C68) Control head?
