I'm in the process of installing a set of ported heads on my stock 82,000 mile LT4 shortblock. I figured I would calculate the compression ratio. I used a micrometer and bridge to find out the average piston deck height...well everything looked hunky dory until #7... .054? That is about .020 off what it should be. The engine ran fine when disassembled, but it has been run hard. I checked and rechecked the measurement, trying different locations, ensuring no dirt particles were causing an error, etc. Even visually, the piston looks further down in the hole than the other 7.
What could cause this...assume the piston and rod are within spec for length? Only thing I could come up with is a failing rod bearing...
Anybody have any thoughts on this? I did not plan to touch the shortblock other than a new oil pan... If it is .020 in the hole from rod clearance then that would mean it is has a rod bearing clearance of ~.050! Does that makes sense? Again oil pressure was fine, no misfires...only question I have is I had recently dragged the car and it was down about 4 mph from the beginning of the year...I was chocking it up to different weather conditions and worn valvesprings...
Re: LT4 Piston Deck Height Discrepancy? Uh oh... (No Go)
I'd think it would be a bent rod before it would a bearing. The rod can be slightly bent and make it run like crap without making you hear anything. If there was that much slop in the bearings you would certainly have had knock.
I'd suggest you go back & double check the deck for flatness using a straight edge & feeler gauges, paying close attention to the area around #7...though I can't imagine that much warp in the deck. Once I had that accomplished I would make sure the pistons are setting squarely in the bore using feeler gauges, as piston rock can affect your measurements. Also make sure you are measuring straight down to the center of the piston, this will minimize the deviation caused by the piston not setting absolutely square in its bore (Piston rock). I have good pics and specs on all of those measurements; I'll go take a look at what all I’ve got...
How could that have occured? I'm quite sure the shortblock is original (bolts, gaskets, etc). I have never filled the engine with coolant (hydrolock, etc) and the valves looked fine as did the cylinder head.
For gee whiz, I computed a CR of 10.5 for that cylinder compared to the others at 11.24 average...
How susceptable is a bent rod to failing...I would like this shortblock to last me another year (383 planned for next winter)...I know that sounds half arsed, but
I agree with MSR on the TDC issue, make sure you find TDC with a travel indicator & again make sure you position the travel indicator in the exact center of each piston so each measurement is consistent & minimizes the piston rock deviation which could result if you are measuring out on the circumference...
I never located TDC per se...I held the bridge over the piston with the micrometer set at a negative .3 and rotated the engine over slowly and watched the maximum number the indicator read.
In other words, I just rotated the engine over and watched the piston top out by reading the highest piston depth...ie: .030, .029, .028, then back down to .029, .030, etc. So .028 is the depth.
The piston is assembled with rings so it doesn't move much...but I did purposely position the micrometer point in the center of the piston (definitely from left to right, but not so much front to back-car direction) as well as carefully scraped off any carbon along with some brakecleaner from piston crown. All the other cylinders were fairly consistent so don't think I did something wrong or different...even checked some other cylinders and rechecked it again...I'm quite sure the piston is lower than it is supposed to be...
Would normal (maybe hard) running bend a connecting rod? Again stock OEM rod-probably a Powdered Metal with a cracked cap...
I'm stumped. This coming weekend I maybe able to examine the lower end...
Thanks for the help folks.
Also I will also check the deck for flatness...I will have to buy another tool for that...:)
no go, i don't think you're doing anything wrong in your measurements. your one piston is obviously more in the hole. if it were a deck issue, the head gaskets would never seal.
it might be a rod out of spec, but i still think it's bent. i've seen a lot of bent stock rods, in both fords and chevies, without good explanations. ymmv, of course, but i wouldn't worry too much about it. (especially since you're getting a stroker in the mid-term future.)
side-note: given the deck clearance (which is very typical for these engines), you're using an impala head gasket, correct?
I guess it COULD be a bent rod, but I would bet on an unfortunate tolerence stack up. We have all heard of the factory freak, that runs better than anything esle? Engines like this, make those possible. Until you tear it down and measure everything, it's all speculation. Good luck, and...
yes, i've seen bent powdered metal rods, in both chevies and fords. it doesn't have to bend much to get the difference we're talking about, it would barely be visible to the naked eye with lots of comparing.
but ya, it could also be a tolerance stack-up. i've not seen the factory stack things up .030" off, though. that's a huge amount out of tolerance, even if you split it equally between the piston pin location and center to center rod length.
do all the pistons look identical? like, you're sure that one is an OEM piston?
