3rd brake light STILL doesnt work
Old Mar 9, 2003 | 04:06 PM
vader86's Avatar
vader86
Default 3rd brake light STILL doesnt work
Replaced all 4 bulbs-nothin
Replaced the switch at the pedal, checked connections which looked ok-nothing happened.
So what do i do now. :confused:
Old Mar 9, 2003 | 05:12 PM
Mike's 86's Avatar
Mike's 86
Default Re: 3rd brake light STILL doesnt work (vader86)
Try checking with a test light at the bulb sockets if you have 12v. If not then try checking if the housing has a good ground. You could try running a external wire to good ground and see if it works. Try to determine what side of the circuits are not working. Wiil check schematic, if I come up with something I'll repost. goood luck :cheers:
Old Mar 9, 2003 | 05:53 PM
Mike's 86's Avatar
Mike's 86
Vader, best I can do on the schematic. :cheers:
12.250.128.183/tech/stoplmp.jpg
Old Mar 9, 2003 | 06:00 PM
vader86's Avatar
vader86
Default Re: 3rd brake light STILL doesnt work (Mike_D)
So, is it possible that there may be a bad connection at the ABS, that would not affect the rear lights?
Old Mar 9, 2003 | 06:04 PM
Siveck's Avatar
Siveck
I sort of have the same problem with my '89 coupe. Not all of bulbs work even when they are new. It pizzes me off when I spend $45 on light bulbs for a third brake light and they don't all work. I think that my housing base is cracked or something and not allowing for a complete circuit on all the bulbs. When I replaced all 4, 3 of them worked. Only a few months later, I am down to one working bulb. I think I need a new bulb base.
Old Mar 9, 2003 | 06:57 PM
jfb's Avatar
jfb
Is 12v across the two wires on the stoplight circuit board with the brake pedal depressed? Is the ground wire on the circuit board going to ground? Are the spring contacts that make with the bulb pins in good condition? If 12v is on the two wires, is it also on the two printed circuit conductors on the ciruit board?
Old Mar 9, 2003 | 09:13 PM
vader86's Avatar
vader86
Default Re: 3rd brake light STILL doesnt work (jfb)
I'm not an electrician, youre gonna have to tone that down to layman level, where is the stoplight circuit board.
Old Mar 9, 2003 | 09:32 PM
vader86's Avatar
vader86
I can tell you what i was thinking of doing, i was going to depress the pedal and see if there was any current getting to the 3rd brake light connection on the switch. (new switch tho) and i'm going to check to see if any current is getting to the bulbs at the connectors, but i dont know what to check for in between.
Its highly possible that the ground has been disconnected, apparently the prior owners didnt know jack about wiring and have screwed a few things up in the car.
Old Mar 9, 2003 | 09:39 PM
jimswhite92's Avatar
jimswhite92
Vader - Check 12V at the switch.
Check 12V at the lights. If you have 12V there, then you have lights (assuming a good connection at the bulbs.)
There is a possibility of a bad ground.
I'm looking at the schematic ... Follow up later ...
Jim
Old Mar 9, 2003 | 10:22 PM
jimswhite92
Well, my software doesn't show a 3rd brake light.
I'll try another source.
Old Mar 9, 2003 | 10:39 PM
jfb's Avatar
jfb
The four sockets that you plug the light bulbs into on the 3rd brake light is a printed circuit board. Two wires are soldered on the circuit board that go to 12v from the brake switch and the other wire goes to ground.
Old Mar 10, 2003 | 09:18 AM
HeeHaw89's Avatar
HeeHaw89
This probably isn't your problem but you never know...I replaced my 4 bulbs recently and they were not coming on when brakes were applied. I lifted the hatch glass and noticed with it open they worked, but did not when it was closed. So I folded/twisted the wires to the light housing in a different direction and they started working. Maybe a wire or wires were getting pinched or something with the glass closed, I dunno but that fixed it and they have worked since.
To 3rd brake light STILL doesnt work
