High beam indicator and Silverstars
Old Mar 10, 2003 | 02:59 AM
JayH's Avatar
JayH
Default High beam indicator and Silverstars
I installed a pair of the Sylvania Silverstars Friday and ever since when I turn the high beam's off, the high beam indicator stays on. I have to turn off the headlamps, and then turn them back on before the indicator goes off. The lights function properly, it's just the high beam indicator doesn't go out when switching back to low beams. :crazy:
Anyone have any ideas?
Jay
Old Mar 10, 2003 | 12:29 PM
jfb's Avatar
jfb
Default Re: High beam indicator and Silverstars (JayH)
You have a poor ground connection at the headlight socket. Clean the socket and the pins on the headlamp. Also, check for good tension on the socket so it firmly makes connection to the headlamp. Check for low resistance of the ground wire from the headlamp socket to ground.
Old Mar 10, 2003 | 01:39 PM
92LT1Roadster's Avatar
92LT1Roadster
Default Re: High beam indicator and Silverstars (jfb)
how to you like the siverstars??? Who much did they cost.
Old Mar 10, 2003 | 01:58 PM
JayH's Avatar
JayH
Default Re: High beam indicator and Silverstars (92LT1Roadster)
jfb: thanks, I'll check the grounds tonight. I'm assuming I want zero resistance between the socket and ground?
92: They're great. Not only is there more light, but it's more widely dispersed than the halogens I had installed. $24.95 per lamp assembly at my local Schmucks.
Jay
To High beam indicator and Silverstars
