Optispark
Old Mar 10, 2003 | 03:49 PM
bwagner's Avatar
bwagner
Default Optispark
Can I get a optispark for a 96 and put it on my 94?
Old Mar 10, 2003 | 03:57 PM
96GS#007's Avatar
96GS#007
Default Re: Optispark (bwagner)
At a minimum you have to change the timing cover.
I believe there were a few other things that had to be swapped as well.
Old Mar 10, 2003 | 08:46 PM
Strick's Avatar
Strick
Default Re: Optispark (96GS#007)
I would say the best approach would be to use a 94 base distributor with a 95/96 distributor cap so you can vent it. Go to http://www.corvetteclinicinc.com and look at C-4 solutions.
Strick :yesnod:
[Modified by Strick, 2:19 AM 3/12/2003]
Old Mar 11, 2003 | 01:03 PM
konroh's Avatar
konroh
to do it right you need a new cam, but minimum you need a timing cover, the upper timing gear, and a longer dowel pin for the cam. On mine, i kept the old cam, but i had to grind the pin on the back of the opti, so that it could mount flush to the cam. I don't know how long this will last though, so i may be going back in for a cam swap and another new opti before i would really like to be.
Old Mar 11, 2003 | 04:30 PM
John Row's Avatar
John Row
From the above replys the obvious answer is, yes.
I agree with Strick above. Simplest is to put the vented cap on a 94 base.
Cheapest is to add the venting to your existing cap. Get the tubing from Jeff Kopp at www.superchevyperformance.com/.
If you do either of these, then be sure to do a good job of sealing the base to the cap and round the electrical connection with some hi-temp RTV.
A more expensive and much better alternative would be to get the Dynaspark from DynoTech. They should have the early version ready either now or very soon. www.dynotech-eng.com/dynaspark.htm
Old Mar 11, 2003 | 07:53 PM
Rick93Z07's Avatar
Rick93Z07
Default Re: Optispark (John Row)
The neatest solution without tearing into your motor with major mods is to:
-install new early style GM distributor ($300) with later purge-style cap ($150) and modify base for purge line. Total cost $450.
-install new Dynotech unit complete with purge cap and base. Costs a little more, but not base mods are necessary for purge line and it has all the design weaknesses addressed such as the incredible shrinking foam around the control wiring that let's water pour in after 3-5 years.
Old Mar 11, 2003 | 09:29 PM
Strick's Avatar
Strick
I never thought of this. How about putting a complete bead of high temp RTV around the entire cap/base? Or is this what you meant? Sounds like a good idea to me. :yesnod: :yesnod: :yesnod:
Strick
Old Mar 12, 2003 | 10:07 AM
John Row's Avatar
John Row
Default Re: Optispark (Strick)
To Optispark
