AC not working?
Old Mar 10, 2003 | 04:37 PM
Jsailor24's Avatar
Jsailor24
Default AC not working?
Recently my AC or heat wont switch from Bi-level setting to any other. When I turn on a diffrent setting, nothing comes from the vents but air comes out of the bottom of the dash. The de-frsoter still will blow air. Any ideas?
Old Mar 10, 2003 | 05:30 PM
Yellow95's Avatar
Yellow95
Default Re: AC not working? (Jsailor24)
I think all that stuff is vacuum actuated. If you have a leak the flappers won't work. Just a quick guess. I seem to remember having a similar problem when I was goofing around under the hood. I cracked a little T connector. :banghead:
Old Mar 10, 2003 | 05:41 PM
Jsailor24's Avatar
Jsailor24
Default Re: AC not working? (Yellow95)
So should I start into the dash to see if somthing by the flapper is broken or looking where under the hood?
Old Mar 10, 2003 | 06:03 PM
tman3222's Avatar
tman3222
6th Gear
Just relaced a vacuum valve, and corrected my problem.
Does your cruise control work? On my car this vacuum leak prevented the vents and CC from working.
This valve has three connections. It is located at the back of the Plenum near the fuel pressure regulator and the distributor. Mine just cooked away. I bought a new one at the wrecking yard for $2.
For CC there is a Servo located just above the battery. There is a vaccum line that runs to a real "T" on the inside of the left front fender. Follow the tube to the right up to the plenum and you'll find the vaccum switch. On the swith to the left is the vacuum from the Plenum. The other connection goes into the car and controls Cruise Control and Air Vents. If the switch looke OK, check all of the tubes for holes or cracks. Some folks have had the line off the servo deteriorate from Battery Acid.
Hope this helps......
Old Mar 10, 2003 | 07:22 PM
Jsailor24's Avatar
Jsailor24
Default Re: AC not working? (tman3222)
I will check it out soon. Thanks for the help. The criuse isnt working either.
Old Mar 10, 2003 | 07:28 PM
tman3222's Avatar
tman3222
6th Gear
Don't wait too long. I am posting about a problem I am having with rough Idle and hick-ups during acceleration.
I am not sure if it is caused by waiting to fix this vacuum thing or not.
Since you are telling me your cc is not working as well, you seem to definitely have a leak somewhere in that vacuum.
Tman
Old Mar 10, 2003 | 08:07 PM
Jsailor24's Avatar
Jsailor24
Well hopefully ill get to it by friday. right now im working on fixing my almost-shot door pannel
To AC not working?
