How difficult to replace ball joints?
Old Mar 10, 2003 | 05:39 PM
nrens's Avatar
nrens
Default How difficult to replace ball joints?
I will be replacing the rack and pinion on my '84 in the near future. How difficult is it to replace the ball joints as well? Is there anything in the knowledge base, like instructions?
Neal :confused:
Old Mar 10, 2003 | 06:25 PM
84FromHell's Avatar
84FromHell
Default Re: How difficult to replace ball joints? (nrens)
I did my lowers about a year ago and although I wouldn't say it was hard I would say it is a PITA ... but I'd rather :steering: them than work on them :D
You can borrow a ball joint press and a pickle fork from Autozone. The rest of the tools you'll need are basic
Old Mar 10, 2003 | 07:16 PM
Bluevette85's Avatar
Bluevette85
Lower ball joint will require a press. For the upper you need to drill off the rivet heads then use a punch to knock the rivet out. This sometimes takes persuasion :smash: You can get a front suspension kit with balljoints and poly bushings here www.p-s-t.com
[Modified by Bluevette85, 7:20 PM 3/10/2003]
Old Mar 11, 2003 | 05:59 AM
pablocruise's Avatar
pablocruise
You don't mention the uppers, but those are a real PITA!!!!!! It's the drilling the rivets out that sucks!
I did all mine with a hydraulic press. The lowers go out with a BANG! Freeze them the night before you do the job. Consider doing the bushings since the arms will be out anyway. More than likely they are really worn. May I recommend poly bushings.
Tedious, time consuming job.
How mechanically inclined are you?
Maybe a search of the archives on "ball joints" will reveal more insight.
To How difficult to replace ball joints?
