88 fans not working
Old Mar 11, 2003 | 05:11 PM
skills68's Avatar
skills68
Default 88 fans not working
Looked at the wires no cuts. Question can i wire them to a switch, and turn them on when I want? :crazy: :smash:
Old Mar 11, 2003 | 05:20 PM
vader86's Avatar
vader86
Default Re: 88 fans not working (skills68)
yes you can wire it to a switch so that it comes on when you want, provided there is no break in the circuit somewhere else
which there probably is, unless the fan motor is dead
Old Mar 11, 2003 | 05:37 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The aux fan sw is on the left block below #1 &#3 plugs; the main fan relay is on the rear of the left inner fender.
In either case to test the fan jumper the Grn/Wht wire to ground and the fan sould come on.
To manually control a fan connect the manual sw between the fan's Grn/Wht wire and ground.
Old Mar 11, 2003 | 06:16 PM
skills68's Avatar
skills68
I want to take the Two power wires to a switch and leave them on when the car is off, will this work? :confused:
Old Mar 11, 2003 | 06:40 PM
65Z01's Avatar
65Z01
To switch them on with the engine stopped but ignition on you only need to run each Grn/Wht wire to a DPST switch.
To switch them on with the ignition off requires that switch and you need to supply unswitched power to the relays. That takes a little more effort.
To 88 fans not working
