which u joint????
Old Mar 12, 2003 | 12:13 AM
corvette184's Avatar
corvette184
Default which u joint????
on a 1985 vette putting in a richmond 6 speed.... which yoke do i want 1310 or 1330 or 1350 style u joint..........getting ready to order a yoke from dennys driveshaft........help :party:
Old Mar 12, 2003 | 08:48 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: which u joint???? (corvette184)
Unless you are modifying the driveline for the superior 1350 series, you need the 1310 to match the weld yoke in the driveline. You can provide u joint dimensions (cap dia & snap ring to snap ring) from your old yoke as a confirmation, but the C4 has a 1310 trans to RA shaft. I can't believe Denny's doesn't know this. Good luck, and...
RACE ON!!!
Old Mar 12, 2003 | 09:27 PM
corvette184
Default Re: which u joint???? (CFI-EFI)
i havent called dennys yet..........i was getting info ready to order one in the am....thanks for the info :yesnod: :yesnod:
To which u joint????
