cam swap questions..
Old Mar 12, 2003 | 06:08 AM
devilfish's Avatar
devilfish
Default cam swap questions..
My old cam is out. And the new is pushed in. Now how do I align it all up?
thanks
Old Mar 12, 2003 | 06:39 AM
devilfish's Avatar
devilfish
Default Re: cam swap questions.. (devilfish)
my crank gear dot is at 12 o clock should the cam gear dot be at 12 o clock then?
[Modified by devilfish, 1:48 PM 3/12/2003]
Old Mar 12, 2003 | 08:12 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If it's ground the same way as the stock then it should go in the same as the stock one came out.
If that info is not on the cam card, contact the mfg.
Old Mar 12, 2003 | 08:31 AM
scorp508's Avatar
scorp508
You worry about that part when you install the timing chain. The upper and lower timing gears will both have timing marks on them. You want them both at 12 o'clock if #6 cylinder is at the firing position or the cam gear mark at 6 o'clock and the crank gear mark at 12 o'clock if #1 cylinder is at the firing position.
I might of gotten that backwards, I can never remember. :D
Old Mar 12, 2003 | 09:19 AM
devilfish's Avatar
devilfish
Default Re: (scorp508)
ok i got the timing mark at 0 degrees before i took the balancer off. So that should be no 1 cylinder at TDC right?
When I took the old stuff out , the crank gear marks whas at 12 o clock, and the cam gear mark whas at 12 o clock.
Should I install the new cam the same way? Its a hot cam.
Regards
Old Mar 12, 2003 | 09:44 AM
MrJay's Avatar
MrJay
You can put it in the same way as you took the other out 12-12 or you can put it in the other way 12-6, because when you are at 0 DTC both pistons are at DTC #1 and #6.
If you put it in 12-6 like I all ways doing you will have #1 fireing and #6 pushing the exhaust out but if you put it in 12-12 then you have #6 fireing and #1 pushing the exhaust out.
I like to do it 12-6 then you have them closer makes it easy to see if you have it right or not.
Jay
Old Mar 12, 2003 | 11:37 AM
devilfish's Avatar
devilfish
Default Re: cam swap questions.. (MrJay)
hmmm.. Does that mess up the ignition?
so crank gear spot at 12 o clock and cam gear spot at 6 o clock thats all i need to do?
Old Mar 12, 2003 | 12:25 PM
MagikDraggin's Avatar
MagikDraggin
Cruise-In IV Veteran
Cruise-In V Veteran
If that's all there is to it, then what's with all this jabbering about "degreeing" the cam?
Karl
Old Mar 12, 2003 | 12:34 PM
scorp508's Avatar
scorp508
It honestly doesn't matter which way you put it because the crank turns twice as fast as the camshaft does. So no matter what way you put it in, it will be the OTHER way after 1 turn of the crankshaft. The worst thing that can really happen is that you'll have the distributor off 180* when you put it in if you guess wrong at weather #6 or #1 was in the firing position.
If you want once you get the timing set installed (either way) put a lifter into place for the exhaust lobes of #6 and #1. Tturn the crank clockwise and keep a sharp eye on the those two particular lifters. Whichever exhaust lifter starts to move up first is the cylinder that was in the firing position. Turn the crank back to 0* and then when you put the distributor in you want the rotor pointing at that cylinder's terminal in the cap.
Old Mar 12, 2003 | 12:54 PM
MrJay's Avatar
MrJay
You did not say anything about the ignition, you have to have #1 fireing ( at TDC) when you put in the distributor in and the bottom has to be pointed at number one.
Degreeing a cam and just installing is two different things, installing is just to put it in and use the marks that you have and if the cam is made right then you dont have to worrie about it, but some engine builders want to know if the cam is doing right so they put a degree wheel on the engine and they make sure the cam opens and cloes at the right time.
If you have the Hot Cam it should look something like this:
Intake @050
1 BTDC befor top dead center
37 ABDC after bottom dead center
Exhaust @050
50 BBDC befor bottom dead center
-2 ATDC after top dead center
Some engine builders want to open and close the valves different then what the cam maker wants so they advance and retire it to make it open where they want.
Hope this helps
Jay
PS what ever scorp508 is saying.... :D
If you put in the 12-6 then the should be fireing so you would put the distributor so it would be fireing at #1 but if you put it in 12-12 then you have to put in the distributor with #6 fireing or turn it over and make sure you have #1 at TDC for fireing and put it in... that is what we do.
[Modified by MrJay, 12:03 PM 3/12/2003]
To cam swap questions..
