schrader valve
Old Mar 12, 2003 | 11:23 AM
mike 1985's Avatar
mike 1985
Default schrader valve
i need to run a line off of the schrader valve, any body know what size the fitting is? I'm hoping i can just flare a 1/4 hard line to it?
Yhanks
Mike
Old Mar 12, 2003 | 11:58 AM
VetteNoob's Avatar
VetteNoob
Default Re: schrader valve (mike 1985)
I believe the sharder valve is an AN-4 fitting. I found a place in Houston, TX that had the fittings I needed to convert the -4 to a 1/4 pipe with a 90* turn without having to spend $30+ at Summit or Jegs. The total cost was $13.21+shipping. Im sure you can find come place local, but if you cant you can call:
GHX Inc
4360 Gessner
Houston TX 77041
713-939-7423
Part#s
2242-2-4S
2071-4-4S
These are carbon steel fittings and not the anodized aluminum fittings. Ill take a pic of it if it helps any.
Old Mar 12, 2003 | 06:22 PM
mike 1985's Avatar
mike 1985
Default Re: schrader valve (VetteNoob)
thanks, that's just what i was looking for
Old Mar 12, 2003 | 06:37 PM
VetteNoob's Avatar
VetteNoob
here is a pic of what i have
To schrader valve
