87 hydraulic clutch hose
Old Mar 12, 2003 | 02:19 PM
c4cruiser's Avatar
c4cruiser
Default 87 hydraulic clutch hose
I've been having some problems with the hydraulic clutch slave cylinder. There is air getting into the system and causing some shifting problems.
My mechanic recommended replacing the slave cylinder rather than rebuilding it. He also suggested replacing the hydraulic hose that connects the slave to the hard line coming down from the clutch master.
After a bit of searching, I've found out that the GM part (10046506) is discontinued!! :mad I have yet to find an aftermarket source for it.
Ideas? Sources? BTW, Jeff Kopp told me they were discontinued and a source I know at GM said the same thing.
