I bought an Accell rail-mounted FP gauge from Jeg's. They had 2 diff. part #'s, one for 85-89 TPI, the other for 90-96. I get the part and the box says 86-96 :confused: Trusting Accell and Jeg's, I install it and it leaks where the fitting meets the stem toward the gauge, just above the Schrader valve :mad
I'm sending the part back, but I don't want the jokers to send me the same part and have the same thing happen.
So maybe some of us can compare Schrader valve measurements to see if there is a big diff. in dimensions between the years.
The measurements of my 85 4+3 are:
distance across top of valve - 6mm
distance from top of valve to end of threads - 15mm
distance from top of valve to fuel rail - 20mm
I called Accell, and they had no part listed for the 85 - just 86-96. They gave me the Accell tech line #, but that Mike joker hasn't returned either of my calls.
TIA to those, if any, that take the time to do this. :seeya :steering:
I went through the search of looking for the correct filling for a FP gauge not too long ago. The schrader valve is a male AN-4. Whatever goes on it will need to be a female AN-4. Your FP gauge fitting is most likely a 1/4" pipe connector so you will need to convert it from an AN-4 to 1/4" pipe. I went with something like this because it was cheaper than the $30 jobs from Summit.
VetteNoob,
Is that your FP gauge right there, or is that an isolator to run your gauge in the cockpit? The only isolators that I can find right now are for carburated applications. AutoMeter was working on one for FI, but I'm not sure if it's out yet. If you have a part number, let me know.
The schrader is a #4 AN. The back of my indicator is also pipe thread, but it came with a pipe to AN union. I just used a short flexible aircraft line to mount my gauge on the firewall. You can also get some #4 B nuts and ferrules and make your own line out of aluminum or steel. The aircraft flare on AN hardware is 37*, but an automotive flare of 35* will work and not leak.
Vettenoob,
Didn't I send the fittings with the guage? I paid $15 from a local speed shop for the fittings, and they looked exactly like the one you have now, except they were blue...
Nice fuel pressure guage though :D
Tim, you did, but the ones you sent swiveled and developed a leak at the o-ring. I priced a fitting like the one you sent and they wanted $30 for one (shipped) so I decided to get one from a fitting shop in Houston. That thing you see cost like $11. I have an Aeroquip catalog for all my fitting needs. :D
Yeah, Id say that's one of the best $100 I spent. I should find more like the one I bought from you and get them exchanged by Autometer and sell them :lol: .
vettenoob, thanks for the response and pictures, but I can't open the pics here at work (filter). But let me see if I got this straight. I have to convert the fitting on the gauge, not attach a fitting on the valve? The fitting on the gauge won't come off the assembly, so I buy something to attach to it, then to the valve? :confused: Sorry for not following if I have it wrong! :seeya
The fitting on the fuel rail does come off, but I found that the plenum gets in the way of anything I try to put there is I dont 90* it away from the rail. Im not certain what the fitting size is for the rail itself.
The fitting on the back of most FP gauges I have found were 1/4" pipe fittings and the schrader valve fitting is #4. This leaves you with having to find converters to turn your male 1/4" pipe into a female #4.
Essentially I think what you will need is:
female 1/4" pipe to female AN #4
Then all you have to do is determine if you need to angle it out away from the fuel rail to clear the plenum.
