Trying to take runners off need help
Old Mar 14, 2003 | 11:46 PM
RichAshley-Black99's Avatar
RichAshley-Black99
Default Trying to take runners off need help
Ive got the passenger side off I cant get the torx thats in the middle off to the side of the preasure regulator how thw hell do you get to that :cuss :cuss
Old Mar 14, 2003 | 11:50 PM
severe-1's Avatar
severe-1
Default Re: Trying to take runners off need help (AshleyRL-87Conv)
Snap on makes a real long torx socket. This works real well.
The Sears Torx set is very fragile.
Old Mar 15, 2003 | 01:09 AM
RichAshley-Black99
Default Re: Trying to take runners off need help (severe-1)
Ive got all the torx off except for that one next to the fuel regulator how the hell do I get to it do I have to take the fuel rail off? :cuss
Old Mar 15, 2003 | 09:54 AM
want2drivemy85's Avatar
want2drivemy85
i believe you will have to atleast unbolt the fuel rail to get to it
h rocks's Avatar
h rocks
Get a manual and quit cussing.
Old Mar 15, 2003 | 11:03 PM
Vic'89's Avatar
Vic'89
Default Re: Trying to take runners off need help (h rocks)
No need to remove the fuel pressure regulator.
Use a long extension and slip it in from the pass side.
Vic
Old Mar 15, 2003 | 11:28 PM
atotalnincompoop's Avatar
atotalnincompoop
Default Re: Trying to take runners off need help (Vic'89)
Vic
:iagree: :cheers:
Old Mar 15, 2003 | 11:35 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Vic'89 is right; I just this PM put mine back and a long 3/8" extension with a thin body Torx and a swivel works fine.
Old Mar 16, 2003 | 10:58 AM
RichAshley-Black99
Default Re: Trying to take runners off need help (65Z01)
Got it just used 2 small 3/8 extensions just the rite length came rite out.. not to bad after all, got the base off as well getting it all bead blasted and cleaned up today then Ill go to work with the dremel Thanks guys :seeya
To Trying to take runners off need help
