FX-3 trouble code 13 ?
Old Mar 15, 2003 | 03:01 AM
Kehrer923's Avatar
Kehrer923
Default FX-3 trouble code 13 ?
I have a trouble code 13 in my computer? I went through the factory service manuel. First, i turned the ignition key on and the motor turned. I a disconnected shock from the sensor, the sensor conections all look fine. I can pretty easily turn the valve on the shock. I also checked the connection and they all have 5 volts. I put everything togher and it still didnt work code 13 so then i switchedthe shocks on each side and i still get a code 13. :smash:
Old Mar 15, 2003 | 03:42 PM
Kehrer923's Avatar
Kehrer923
Default Re: FX-3 trouble code 13 ? (Kehrer923)
Old Mar 15, 2003 | 07:05 PM
1MoorTym's Avatar
1MoorTym
Code 13 is a left front time out, meaning the damping adjustment motors are moving too slowly or not receiving the correct feedback signal.
Did you follow all the troubleshooting in the shop manual. Actuator must turn both ways when power is applied and then there are three different tests for voltage across three different pins.
If all this is ok, the actuator is bad. Check it all out and swap it for the right side and see if you get error 14.
To FX-3 trouble code 13 ?
