final check.
Old Mar 15, 2003 | 05:45 PM
devilfish's Avatar
devilfish
Default final check.
Sorry for my nag, but I rather ask to much then screw up.
If I install the cam 12 o clock the dis should be pointing at no1 cylinder. And if I install it 6 o clock it should point at cyl no 6? Right?
Old Mar 15, 2003 | 05:48 PM
Corvette0096's Avatar
Corvette0096
Default Re: final check. (devilfish)
Yep, If you where to take a straight edge and lay it across you rotor it should be pointing at the second intake bolt on the driver side.
Old Mar 15, 2003 | 05:54 PM
devilfish's Avatar
devilfish
Default Re: final check. (corvette0096)
ok so 12 o clock on the crank gear "spot" and 12 o clock on the cam gear "spot". Thats all there is to it?
Old Mar 15, 2003 | 05:58 PM
Corvette0096
When the dots are closest to each other that is on the compression stroke #6
To final check.
