406 cooling question
Old Mar 15, 2003 | 09:22 PM
LD85's Avatar
LD85
Default 406 cooling question
My 85 has the Heavy Duty cooling option (V08) which is two fans, one to pull air and one in the front of the radiator to push.
Anyone with a 406 running found that this set up wil lhandle the 406 heat issue or possibly use both fans at once or is it necessary?
I am about to buy the Flow Kooler water pump and wonder if my stock radiator will handle the 406 heat with two fans!?
Any experiences, thoughts?
Old Mar 16, 2003 | 01:08 AM
HWoods's Avatar
HWoods
Default Re: 406 cooling question (ld85)
I have a 415 in my 86 and it tends to try to run pretty warm down here in Houston. I have an aftermarket all aluminum radiator, Flow Kooler water pump and went to the Spal dual puller fans and have the pusher fan in front of the radiator too. Remember the more horsepower you try to make the hotter the engine is going to try to run.
Old Mar 16, 2003 | 07:04 AM
LD85's Avatar
LD85
Default Re: 406 cooling question (HWoods)
Well thats what I thought, just another new part to buy :lol: :D
Old Mar 16, 2003 | 08:50 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
I think you will be fine, provided long traffic waits are not in your plan. Mine runs no hotter than the 350 did, and corkvette1 ran his for quite some time in the past with his setup. Surely though, an aftermarket b cool or something is gonna perform better. I would try it without, then upgrade if necessary.
Old Mar 16, 2003 | 09:36 AM
LD85's Avatar
LD85
Default Re: 406 cooling question (ski_dwn_it)
Thanks Jesse, I plan on leaving it stock and playing with the fans. I want to get the motor in and working along with the new 165 ECM first then I can address those issues.
Congrats again on the new motor!
Old Mar 16, 2003 | 02:58 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
make sure you clean the debris from in front of the rad between the rad and condenser :cheers:
Old Mar 16, 2003 | 03:23 PM
Ironcross's Avatar
Ironcross
Horsepower should add no heating problems as long as you run the same cooling configuration of the stock engine that was replaced. :thumbs:
To 406 cooling question
