Is there a bulb here?
Old Mar 16, 2003 | 10:16 AM
92TripleBlack's Avatar
92TripleBlack
Default Is there a bulb here?
The switches for the headlights don't "light up" when I turn on the lights like the rest of the dash. Do I have a blown dash bulb? If so, does anyone have the part number and description of how to get at it?
Old Mar 16, 2003 | 03:59 PM
don hall's Avatar
don hall
Default Re: Is there a bulb here? (92TripleBlack)
This isn't much help, but I can email you the instructions to remove the light switch. Unfortunately, the instructions do not mention how the panel is illuminated, or the source of the illumination. I'm interested in the solution, as none of my three manuals provide a clue.
Old Mar 16, 2003 | 08:18 PM
corvette184's Avatar
corvette184
Default Re: Is there a bulb here? (Oldman)
i am pretty sure it does not light up..........all of my gm cars are not lit up either..........95 tahoe and a 96 grand prix are all dark on the switch......kinda weird huh :skep: :skep:
Old Mar 16, 2003 | 08:25 PM
don hall's Avatar
don hall
Default Re: Is there a bulb here? (corvette184)
All the switch positions are illuminated along with all the panel lights, when the switch is activated. But I can't tell you how they are lighted.
Old Mar 16, 2003 | 09:09 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Cruise-In II Veteran
Currently Corvette-less
Open the driver door and remove the hard plastic panel that is next to the dash. I think that it is held in place with 3 torx screws.
Once the panel is removed, you can access the back of the switch. The Lights are actually behind a little round plastic holder, a little lerger in diameter than a pencil eraser. The plastic piece has a straight screwdriver slot (recessed) in the back.
If you contact Jeff Kopp he can supply the lamps.
~ Purp :yesnod:
[Modified by PurpleC4, 7:10 PM 3/16/2003]
Old Mar 16, 2003 | 10:04 PM
don hall's Avatar
don hall
Default Re: Is there a bulb here? (PurpleC4)
Thanks, PurpleC4......good reply :thumbs:
Old Mar 17, 2003 | 08:47 AM
92TripleBlack
~ Purp :yesnod:
I'll get it this weekend.
:thumbs:
Old Mar 17, 2003 | 01:52 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
It has been a long time ~ but to my memory, there is more than one. You should just remember that every button lights up.... even the ASR button.
~ Purp :iagree:
Old Mar 17, 2003 | 02:07 PM
don hall's Avatar
don hall
PurpleC4, it doesn't seem right that all the lamps would fail at the same time. There must be a common disconnect.
Old Mar 17, 2003 | 02:44 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Oldman,
Yeah ~ :iagree: that is rare, however.... when I bought my 92 Coupe (used) they were all blown on mine. I have since learned that the circuit which controls that side of the instrument cluster also controls the driver door lights. A good check would be to see if the night lights work on the driver door when the headlights are on.
~ Purp
Old Mar 17, 2003 | 02:58 PM
don hall's Avatar
don hall
Purp...all my lights work. I just think that when you activate the headlight switch, and all the panel lights go on except those surrounding the switch, there must be a common connection to have those lamps fail at one time. Maybe 92TripleBlack will provide some feedback after he sorts out his problem. Thanks!
Old Mar 17, 2003 | 03:57 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Oldman,
Very good point. I think we have provided enough information to make the proper assessment. Thanks for the clarification on the issue. Often, we focus on the specific question and not all the surrounding circumstances.
~ Purp :cheers:
To Is there a bulb here?
