better gas mileage from midgrade???
The difference in MPG between different grades of gasoline depends on your engine and it's requirements... You'd be surprised that even some of today's economy cars run a little better on midgrade than regular... I've never seen it work the other way around like you're observing, where midgrade gave better economy than premium...
My ex-gf's base 2.2L Cavalier did a little better (1-2mpg) on midgrade than regular, but premium did nothing over midgrade...
My Vette, only got regular a couple of times in it's life... Both times I noticed about 2mpg decrease with regular... So I didn't really see any savings since I'd need about 2 more gallons of regular to go the same distance as premium...
My 94 Northstar Eldorado is the same way... The dealer gave me a full tank of regular gasoline when I bought it... The vehicle is marked "Premium Required" and that first tank of gas didn't last very long, nor did it accellerate correctly at WOT (pinging)... I ran the tank almost dry and filled up with Premium and the power and performance returned...
Every modern car I've ever owned ran better with either midgrade or premium...
All that being said, I'm going to fill up with midgrade next time. I've been running premium since I bought the car, and it might not be giving me any gains. :crazy:
[Modified by CentralCoaster, 2:04 AM 3/17/2003]
A long time ago I had a 78 Buick LeSabre with a whimpy 301V8... I believe the CR on that car was 8.5:1... That car never had premium or midgrade ran through it and never had any pinging issues... I think the lowest compression 350 TPI motor was 9.5:1, which would benefit from midgrade and premium...
From what I remember about gasoline and octane rating was that you run the lowest octance you can without detonation... The higher the octane, the slower the burn, but you do get the resistance to pre-detonation which is worse than the slower burning fuel...
Race fuel is expensive so I'll just add octane booster to pump gas:- BIG MISTAKE, first pump fuel is notoriously inconsistent in its blend, often changing weekly if not daily. Different manufacturer's mix fuel in different ways. If you travel across the country to ride then fuel can and does change between area's. therefore you have no baseline to work from. How much octane booster will you need? You will never know. Add to this the fact that octane booster's will only increase the octane by small amounts, no matter how much you add, you will get problems.
The first test to determine the (research octane rating)RON rating of the fuel is done at low rpm's and cool conditions, this is not realistic for use in a high revving engines.
The second test to determine the (motor octane number)MON is more realistic as it is carried out under higher rpm's, higher temperature's and grater load's.
Check out the trype of ratings at your pumps.
:auto:
This was on an L88 vette with 12.5:1 comp
[Modified by sumoboy, 1:51 PM 3/17/2003]
[Modified by sumoboy, 1:53 PM 3/17/2003]
