Engine Knock - Too Lean or Too Much Timing?
What I'm wondering is if the carb (Holley 750 DP) is just going too lean when the secondaries just dump open causing the engine to knock. It seems when I ease into the pedal, or downshift and then floor it, I don't hear this knock even with the timing advanced more.
My engine specs are as follows:
383 LT1 (modern) running 11.7:1 compression
Holley 750 DP (stock jets)
GM Carbed Dual Plane Intake
Comp Cams CC306 w/ 1.6 RR (duration @50 230i/244e w/ lift .544i/.576e)
Aluminum Heads "Stage II" ported (flows 265i/190e @.50 w/ 2.02/1.6 valves Hooker LT Headers
Dual Flowmaster Exhaust
3.55 rear end
2500 stall
TH-350 trans
160 deg thermostat
MSD 6AL
Meziere electric water pump
It seems I can run around 34* timing w/ a quicker advance if I'm not flooring it while cruising in 3rd gear. Is it possible that I'm getting knock still but just can't hear it over the engine?
Does this sound like too much timing or too lean a fuel mixture?
Thanks!
Car likes 34 deg. if I run 50:50 103 octane/93 octane.
11.7:1 on pump gas seems like an awful lot of compression without a computer.
Just my $0.02
that said, i also think you should use a wideband to see what the a/f ratio is. that tool alone will make things a lot easier.
dyno it if you get a chance, i've always wondered what sort of power curve that dual-plane intake provides...
