1987 Temperature Gauge
Old Mar 17, 2003 | 11:16 AM
Autiger1's Avatar
Autiger1
2nd Gear
Default 1987 Temperature Gauge
My 87's temperature gauge is maxing out at 299 but the engine is not overheating. I found a technical service bulletin # 87162 from June 87 that reads: temperature gauge false indicated overheat condition. It did not give a solution to the problem, someone please help I've tried everything.
Old Mar 17, 2003 | 11:40 AM
Fast Glass's Avatar
Fast Glass
Default Re: 1987 Temperature Gauge (Autiger1)
Heres what the service manual says to do:
Test M- coolant temp indicates high temps continously.
Disconnect the coolant temp sender connector and turn ign switch to run. r/h side of eng near starter solenoid. Its a single wire.
If the collant temp display indicates lo, replace the coolant temp sender.
If the coolant temp display does not indicate lo, check the dark green (35) wire for a short to ground. If the (35) wire is ok, replace the inst cluster.
Its pretty simple to check, and most likely the temp sender is bad.
Good luck.
Old Mar 18, 2003 | 01:27 PM
Autiger1's Avatar
Autiger1
2nd Gear
Default Re: 1987 Temperature Gauge (Fast Glass)
I went back and cleaned up the connection on the green wire with a little sand paper, gauge seems to work fine now.
To 1987 Temperature Gauge
