What can cause this?
Old Mar 17, 2003 | 12:59 PM
LayZ's Avatar
LayZ
Default What can cause this?
I have alot of shake in the car at higher speeds. The steering wheel will shake and i feel alot of vibration in the seats. I had the wheels aligned and balanced and it was better, but still not nice and smooth. I would say i begin to notice it around 60mph and really feel it at 74mph. What can i do to make the ride smooth?
Old Mar 17, 2003 | 01:39 PM
vader86's Avatar
vader86
Default Re: What can cause this? (LayZ)
run a search, look for vibration at speeds or high speed vibration
This has literally come up a thousand times, its a very common problem. I think someone replaced a shaft on the back of their transmission once and fixed it altogether but i'm not sure.
Old Mar 17, 2003 | 01:44 PM
cprgmr's Avatar
cprgmr
Do you have the top off when it happens or does it shake all the time?
Old Mar 17, 2003 | 02:18 PM
sumoboy's Avatar
sumoboy
Default Re: What can cause this? (vader86)
I just read about that, I think in this months corvette fever.
Complained about the same type of problem. Also...what type of balancer did they use on your wheels?
[Modified by sumoboy, 7:32 PM 3/17/2003]
Old Mar 17, 2003 | 02:19 PM
atotalnincompoop's Avatar
atotalnincompoop
Default Re: What can cause this? (sumoboy)
sounds like a u-joint to me :yesnod: :cheers:
Old Mar 17, 2003 | 04:47 PM
LayZ's Avatar
LayZ
top was on, i was just going to start replacing the drive shaft, half shafts and bearings until i fixed it. Just looking for a good place to start first. I had a guy tell me my rims and tires where out of round? i guess it could happen but it sounds like a crock.
Old Mar 17, 2003 | 04:54 PM
John Row's Avatar
John Row
Before you rip it appart, check the simple stuff. Tire pressure and balance (take it back and have them check it again).
Wheels and tires can get out of round. The tire shop should check this as well.
While it's in the air, check wheel bearings and steering gear.
Like it was said, do a search for the other 127 things that can cause this.
To What can cause this?
