Gear change info
Old Mar 17, 2003 | 09:55 PM
az28's Avatar
az28
Default Gear change info
What is the best gear ratio setup to get better accelaration, but not be buzzing
the engine on the highway? I have a '93 with auto. trans. Thanks!
JR :flag
Old Mar 17, 2003 | 09:57 PM
SHiNoBi LT4's Avatar
SHiNoBi LT4
Default Re: Gear change info (az28)
in my opinion for an auto... stock is best or maybe 3.54s. Although i had a 4.09 in my six speed.. i really prefer a long steady pull on the freeway than annoying quick shifts. :cheers:
Old Mar 17, 2003 | 10:12 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I put 3.45's in, those are probably the best all around ratio for dual purpose.
I improved my 60' time and et at the track, yet still retain good mpg on the road(just don't ask me anything specific about rpm or mpg, because I didn't jot any notes down.)
Old Mar 17, 2003 | 10:22 PM
az28's Avatar
az28
Default Re: Gear change info (Mr Mojo)
Does anyone know what the stock ratio would be? Thanks
JR :flag
Old Mar 17, 2003 | 10:27 PM
Mr Mojo's Avatar
Mr Mojo
Your stock ratio is 2.59(RPO GM1) unless you have RPO G92 which is the performance axle,3.07 gears which is RPO G44.
Old Mar 17, 2003 | 10:39 PM
tuband's Avatar
tuband
Cruise-In I Veteran
:iagree:
I recently changed my 2.59 gears to 3.31 gears and I heartily recommend this ratio. I don't race but I enjoy good acceleration and still be able to have a nice RPM range for interstate cruising speeds. For me the 3.31 works well. I think 3.54 might be a little too much but if I had changed from the D36 to the D44 I would probably go with the 3.45. Otherwise, the 3.07.
Old Mar 18, 2003 | 02:53 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
It's all about what you are going to do with the car...I run my 93 at the drag strip every month so I have 3:73's...I also cruise on the hwy just fine at 80 mph and it's my daily driver...good luck
To Gear change info
