roller rockers
Old Mar 18, 2003 | 09:19 AM
devilfish's Avatar
devilfish
Default roller rockers
Two questions:
1: What is the propper way to install roller rockers? I just did my cam swap. And im going for 1,6 rrs.
2: Is fully roller rockers going to make more HP then just roller tiped once? Or is fully roller "just" more gentel to the vavle train? The thing is I can get a set of 1,6 roller tips for free :) But I just whant to check this first.
Old Mar 18, 2003 | 09:31 AM
Fatt Vette's Avatar
Fatt Vette
Default Re: roller rockers (devilfish)
It has always been my opinion, that the roller tipped rockers do not do much. Its the fulcrum that develops most of the friction and heat. Again, just another engineers opinion, maybe there is some testing to back me up, I have never looked.
The LS1 engines, when new, have aluminum rockers with roller fulcrums and sliding tips.
Matt
Old Mar 18, 2003 | 09:33 AM
FoolCrzy's Avatar
FoolCrzy
Default Re: roller rockers (Fatt Vette)
:withstupid:
Old Mar 18, 2003 | 09:40 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
With a hydraulic cam install full RRs as you would stock rockers.
Then take the "free" roller tips, sell them and get a set of full RRs for your buildup. You've come this far, go the last step.
Old Mar 19, 2003 | 03:08 AM
devilfish's Avatar
devilfish
Default Re: roller rockers (65Z01)
ok, good ide. :D
But to get back to my main question. Is 1,6 roller tip rockers going to make the same power that fully roller, but make more stress on the valve train?
thanks
Old Mar 19, 2003 | 03:26 AM
pablocruise's Avatar
pablocruise
check if they self aligning? check size stud?
I have the CompCams ProMagnum full rollers. I am very happy with them. I took off the valve cover and started the motor. They do not get hot and I think they are supposed to save 1 or 2 hp. Someone will correct me.
Old Mar 19, 2003 | 11:44 AM
devilfish's Avatar
devilfish
Default Re: roller rockers (89 Paul in Cal)
so the roller tiped rockers will make my car go bad, and mayby even brake due to heat?
Old Mar 19, 2003 | 11:46 AM
scorp508's Avatar
scorp508
thanks
Maybe or maybe not. Without knowing what a full roller would do on your engine its hard to say with certainty. :)
Old Mar 19, 2003 | 12:01 PM
VetteNoob's Avatar
VetteNoob
Think of it this way. The roller tipped rockers have increased friction as previously mentioned. Friction will create drag and heat. Drag and heat typically reduces performance. Whether the decrease in performance is noticable or not, I dont know. But I do know it doesnt help performance to have roller tipped rockers over the full rollers. If it doesnt help, there isnt too many directions to go from there. Just my $.02
To roller rockers
