I've been doing a number of upgrades and I broke the locking clip on the throttlebody electrical connector. Does anybody have a fix for these broken clips? I have a few others that are broken, too. They sure are brittle.
Eckler's carries the connectors for the throttle body - there are three, throttle position, temperature and idle air control. At least one of the connectors is available at Pep-Boys - I bought one there. You have to figure out how to remove the pins from the old connector and install them in the new connector - otherwise you have to splice the wires.
I just found a year one catalog and found weather pack plugs for GMs. They even had the extractor tool so you don't have to splice in a pig tail. They have a web site: http://www.nextgenparts.com
Strick
Now if I could just figure out the plug wire loom problem :banghead:
