Need Help Identifing a Part
Old Mar 18, 2003 | 06:49 PM
mn_vette's Avatar
mn_vette
Default Need Help Identifing a Part
In my rear storage compartment behind the passenger seat, under the plastic tray, behind the carpeting there is a tin box velcro-ed to the side of the compartment. It has several wire connections comming in/out of it. Does anyone else have one of these? Does anyone know that it is???
I'll see if I can get a pic after dinner. Thanks :cheers:
Old Mar 18, 2003 | 07:21 PM
mn_vette's Avatar
mn_vette
Default Re: Need Help Identifing a Part (mn_vette)
lets try this....
any thoughts on what it is??? Some of that wiring mess is from my nitrous system, the wiring harness isn't though.
[Modified by mn_vette, 12:42 AM 3/19/2003]
Old Mar 18, 2003 | 07:23 PM
Nathan Plemons's Avatar
Nathan Plemons
I think it's the radio tuner. My 92 is under the dash but they moved it in later years.
Old Mar 18, 2003 | 07:29 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default Re: Need Help Identifing a Part (Nathan Plemons)
It looks like the radio tuner, try to unplug a connector and see what changes?
Old Mar 18, 2003 | 08:17 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
In some model C4's, it's the ABS brake system.
If you don't see any hydraulic lines going to or from it then maybe it isn't :rolleyes: :D
:seeya
Old Mar 18, 2003 | 08:21 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Need Help Identifing a Part (jackdaroofer)
:seeya
The ABS is behind the drivers seat, the passenger side is the tuner.
Old Mar 18, 2003 | 08:28 PM
SPEED750's Avatar
SPEED750
Default Re: Need Help Identifing a Part (Mr Mojo)
I don't think that is factory.My 92 has ABS behind drivers seat in a screwed down compartment and tuner module is under dash on passengerside.Your car is a year newer and that looks "tacky".It's suppose to get more refined from one year to the next.I would guess the previous owner did it.Maybe aftermarket alarm, keyless entry, ect. :steering:
Old Mar 19, 2003 | 07:50 PM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
:withstupid: it's the stereo tuner :D
To Need Help Identifing a Part
