How do I get the front and rear speakers out of the car? My blose amps have had it, they are to the point of just crackling all the time. I need to remove the speaker enclosures, amps and speakers. Do they just come out as a whole assembly?
I am sending it all off for repair, thanks for your help :cheers:
Its just one big enclosure with a plug on it.The fronts are held in by 4 bolts.The rears, enclosure is two peices, you unbolt the top.The amps are inside the enclosure. :seeya
Can you remove the rear speaker enclosure/amp/speaker as one assembly? Or is that not worth the trouble, since I will probably just be sending the amp and speaker.
The rear is a snap, you remove the grills then its like 4 bolts that hold the top of the enclosure to the bottom.The speakers and amp is bolted to the top.Diconnect one plug and you can take it out. :cheers:
Both front and rear can be removed as a unit. The fronts are a pain because you have to basically take the door apart to get them out. The rears as stated above, are simple - 4 bolts, pull carpet out of the way and they are out.
Whats a blose amp???
Is that something new that I've missed.....
thanks
tony
:confused:
It is what we call the now-very-out-of-date Bose system that came with the car. Usually one of the first mods is to yank all that and put in new speakers, wires, & CD player. Pop over the the Audio section. Lots of great help there. They got me sounding excellent in short order! :yesnod: :lol: :yesnod:
