Mounting position of Intercooler on TT setup?
The ATI system for the 92+ cars mounts the intercooler above the radiator shroud (The fiberglass thing that is over your radiator directing outside air to it). I think this is the best way to go, but that is just my opinion.
The intercooler is not mounted in front of the radiator this way, it is on top of it, seperated by the fiberglass.
Now you can cut a hole in the top of the radiator shroud and have the air that gathers in there push up into the intercooler. like how the vortex rammer works.
Or you can get one of the license plate ram airs that would push air into the intercooler like that, or you could do both, cut the radiator shroud and the ram air plate. Not sure which one works the best due to the aerodynamics involved and the volume of air from each.
You would have to convert your radiator to the laster system (92-96) since yours is not designed for this if you wanted to do this. The later system is layed back more.
Now some C5's (TT Z06 from halltech) and montys C3 have the intercooler against the radiator. Meanys car had this as well.
I am waiting for when monty starts cruising his car on the street to see if he posts about any temp problems.
I had to build a scoop under my car not to get air on the intercooler but to the radiator.
A friend of mine made the forced air piece in the front of the car where the tag hole is. It works great putting air on the face of the intercooler.
I have always had cooling probems in traffic in the past. Hopefully that problem has been solved. We put a 18 inch fan with shroud on it a couple weeks ago and it is amazing. The car wont get over 190 degrees at idle now compared to the 220 plus temps we saw before.
The fan is a Ford fan off a Lincoln. I know, a Ford product on a Corvette, but it moves almost 5000cfm and it works great. We have several turbo cars with this fan on them and it has reduced coolant temps on all of them.
Anyway do you got any pics of your intercooler? YOu corvette is similar to mine besides the CF injection, but I would like to see how exactly you got the intercooler in there. Thanks for the help :yesnod:
These are of Ex golds car
He has his web page right there in his sig, why dont you click and look around his page. He has tons of pics.
[Modified by bill mcdonald, 7:01 PM 3/19/2003]
If you look at the second pic I posted, that is the A/O engeneering license plate ram air, that Ex-gold is using to ram air into his intercooler (you can see the intercooler inside).
Now, if you want to ram air into the turbo inlets/air filters. That would be tricky. More tubes to run around the engine compartment which is going to clutter stuff up. You might be able to run your turbo intake tubes to something which looks like this. buy it, build it, whatever
I have seen Naca ducts put in, like the early callaways Hoods(87's). You could put these cut outs above the turbo air filters.
Or there is a hood cowl that Doug said he was going to use on his C4 TT. it is from greenwood and has 2 slits at the nose of it to let air in which is right where his air filters are mounted.
It looks kind of like the later firebirds ram airs. http://www.greenwoodvette.com/options.htm
[Modified by bill mcdonald, 9:31 PM 3/19/2003]
As for Naca ducts, just doing a search there are these places. I have seen them in racing catalog though. http://www.gospitzer.com/prodline1.htm http://web1933.vs.netbenefit.co.uk/a..._Ducts_29.html http://www.mckinneycorp.com/bodycomp.htm http://www.bakerprecision.com/brkduct.htm <A HREF="http://www.ioportracing.com/Merchant2/merchant.mv?Screen=CTGY&Store_Code=IPRS& Category_Code=DAA" TARGET="_blank">http://www.ioportracing.com/Merchant2/merchant.mv?Screen=CTGY&Store_Code=IPRS& Category_Code=DAA</a>
One problem that the ati intercooler has is that the thing is so small that the end tanks are in front of the radiator. Solid metal don't flow air for poopie.
This winter I replaced my intercooler with a custom built one it is 16x26 inches and I put foam rubber between the radiator and the intercooler so that it seals. All air must go through the intercooler not in through the gap at the bottom like ati could. Intercooler can not cool unless the air flows through it. I installed 16 inch spal fans in front and behind one pushes and one pulls.
I also installed the ram air that Bill made reference to it forces air directly into the intercooler. I have not driven the car in hot weather yet but have no concern about over heating since air flow through the radiator is far greater than a stock corvette I know that mine will run cooler. Some time in the future I will try to put up new pictures as the ones in my gallery are old ones car looks totally different now. I had all custom made parts chrome plated and it looks pretty good. :seeya
Bill, thanks for the links, I just got another question, The naca ducts personally look really good. Do you know how big they were when they came out on the Callaways? Also what about rain? If I'm on the freeway and is happens to rain, how do I solve that problem? Also I think I'lll go with the License plate cutout and the Naca Ducts. I'll use the Nacas to feed the turbos and the plate to cool the intercooler.
Also Bart, What kind of fans are you using? Would two 2000cfm fans be pretty good?
A intercooler the size that you propose to use will flow less than 300 cfm hardly what I would use for a 2000 cfm blower. You need to understand that there are more things to consider than cooling the air you must have a intercooler that matches the output of your blower.
And here is a link to a cfm calculator that uses displacement, boost, rpm, and volumetric efficiency. http://www.smokemup.com/auto_math/airflow.php
I do have to say that I like the idea of mounting the intercooler to the top of the radiator shroud where the airbox used to be. Putting a fan under that should flow enough air across it to make it work well. This may take away from the airflow of the radiator, but there should be plenty of airflow if you are running the car at any real speed to need the cooling. When I do mine I think I'm going to go with two 800+cfm cores. If you put them side by side and give each an individual feed end and have one large output end that covers both core ends I think it would work very well. Then you don't need a Y-pipe to combine the twin turbo feeds into the engine. Can you have TOO big of an intercooler???
[Modified by mn_vette, 9:32 PM 3/21/2003]
Someday I hope to get a real intercooler and try it behind the license plate opening, but let the air exit above the top of the radiator shroud and out thru a hood vent- keeping it completely separate from radiator airflow. And at speed I'd have high pressure up front and low pressure from airflow over the hood; should move air pretty well thru the intercooler.
EX- nice pics of the twin turbo! One curiousity though- you're air intakes are down behind the radiator sucking hot air? How bout turning them toward the wheel well (above the shock mounts maybe) for some cooler air? (Only works if you don't have much rain or road crap)
[Modified by gcrouse, 5:08 PM 3/21/2003]
