antenna help
Old Mar 18, 2003 | 11:19 PM
MYWIFESVETTE's Avatar
MYWIFESVETTE
Cruising
Default antenna help
my electric antenna is broken. the mast is seperated. motor still runs. can the mast only be replaced? :cheers: :auto:
Old Mar 18, 2003 | 11:27 PM
Sam Lam's Avatar
Sam Lam
Default Re: antenna help (MYWIFESVETTE)
The mast and plastic ribbon can be replaced. Suggest you email Jeff Kopp at Superior Chevy for GM replacement parts. He has the best price. His email address is: parts@superchevyperformance.com. Replacing the mast does involve a little work in that you should remove the antenna and clean out the old ribbon.
Old Mar 19, 2003 | 07:51 AM
hngacurv's Avatar
hngacurv
Default Re: antenna help (Sam Lam)
:withstupid:
Old Mar 19, 2003 | 09:13 AM
ROADAPPLE's Avatar
ROADAPPLE
Default Re: antenna help (hngacurv)
The "ribbon" is all you need to replace if the metal mast is not bent. Remember to clean out the old "ribbon" parts when you do the job.
Happy Vetting,
Old Mar 20, 2003 | 10:51 PM
MYWIFESVETTE
Cruising
thanks for the help. i had a mast and cable sent over night. 16.95 plus shipping. better than 157 for a whole new antenna. i did have to take out the antenna take the housing apart and remove broken pieces. works great now. thanks again for the help
:party:
To antenna help
