Need help with engine mods!!!
Old Mar 18, 2003 | 11:19 PM
vetteguy216's Avatar
vetteguy216
Default Need help with engine mods!!!
Keeping in mind that I will have a 383 in a couple of years (after I get out of college). I would like to get some more power out of my car, you know the power that spins the tires when the car shifts. I have been thinking and debating on what I should get and what I should do first. I am now asking for your guys knowledge and experience to help me get a gameplan and someplace to start. I have an 87 with chambered exhaust, open lid, removed screens, and an SR base manifold (not yet installed). The bad news is I have to pass emisions,
Old Mar 19, 2003 | 01:04 AM
drive it's Avatar
drive it
Default Re: Need help with engine mods!!! (vetteguy216)
I would stick with bolt ons that will swap right over to the 383 later on-which means intake and exhaust mods. The base is a good start-get a SR also and you'll notice a diff. The SR base and plenum is also smog legal. Then a hi flow cat.
If you don't mind getting into the engine then a cam swap(etc, etc) would about do it untill you go for the 383. And then the big question....what's the budget??!! :lol:
Old Mar 19, 2003 | 07:49 AM
hngacurv's Avatar
hngacurv
Default Re: Need help with engine mods!!! (drive it)
I don't know how the emission testing works in your area, but if you can use longtube headers I would go for that next. Just get some with the air tube hookups and keep your main cat.
Old Mar 19, 2003 | 01:27 PM
vetteguy216
Default Re: Need help with engine mods!!! (hngacurv)
Yeah I was thinking when I put in a cam I'll put in some roller rockers and lifters. Any suggestions on a decent cam that wont break the budget?
Old Mar 19, 2003 | 01:42 PM
mn_vette's Avatar
mn_vette
Since you are going to be doing the 383 in a few years, you'll probably be redoing alot of the engine components. You might want to try a new set of gears in your rear end.
Old Mar 19, 2003 | 02:36 PM
vader86's Avatar
vader86
Default Re: Need help with engine mods!!! (mn_vette)
Heres what i'm going to do, however SC has no emissions right now.
383, SR, Accel 219 cam, AFR 190 heads with 1.6rr, hooker 2151 ceramic-coated and a Random Tech cat. All that can be made smog legal, but it depends on the exhaust and the tuning.
If you keep the main cat, and just get a Random Tech hi-flow, you could still pass emissions with the right tuning, and just return the car to the 'better' tuning by switching out a chip. If you keep the precats and the main cat, you would be very likely to still pass emissions.
To Need help with engine mods!!!
