weather stripping maintenance
Old Mar 19, 2003 | 09:28 AM
90whitevette's Avatar
90whitevette
Default weather stripping maintenance
I just replaced all the weatherstripping on my 90 vette and would like to know if there is anything I can do or anything I can apply to it on a regular basis to help it last a little longer, as I dont wish to spend the money again anytime soon for replacement. I was thinking about such products as Armour-All but have heard somewhere that these products actually decrease the life of whatever they are applied to (didnt know that, but the writeup I read was extensive and quite convincing). Anyway, does anyone have any ideas you wish to share that may extend the life of the weaterstripping? Thanks in advance. :)
Old Mar 19, 2003 | 09:42 AM
ittlfly's Avatar
ittlfly
Default Re: weather stripping maintenance (90whitevette)
You can spend the $10 a tube for the "weatherstriping" name product OR use diaelectric grease. (same stuff you put into the spark plug boots to keep moisture out). Put a light coat on, rub in well and use a cloth to wipe off any excess. Once every 6 months does the trick. :thumbs:
[Modified by ittlfly, 6:42 AM 3/19/2003]
Old Mar 19, 2003 | 12:45 PM
Iroc's Avatar
Iroc
Default Re: weather stripping maintenance (ittlfly)
:iagree: I got the 3 Silicon Grease tubes offered in MAD. Its been a couple of months since I put it on and it still has a rich semigloss black look to it and thats on a daily driver. :chevy
Old Mar 19, 2003 | 02:13 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
:iagree:
Old Mar 19, 2003 | 03:58 PM
RUSS105's Avatar
RUSS105
Default Re: weather stripping maintenance (edsalinas)
Go to the $1 store and get a can of petrolium jelly. Works on keeping the moisture out and seals from drying out. The best part is that it's cheap. :seeya :steering:
Old Mar 19, 2003 | 10:16 PM
Touringpro's Avatar
Touringpro
Dielectric grease does work, but it's . . . well . . . greasy :lol: GM has an excellent Silicone Emulsion (P/N 10953014) that's made specifically for maintaining weatherstripping and other rubber trim. Applies easily, soaks in in about 15-20 minutes, leaves no visible residue, and makes the rubber soft and pliable. Around $5 for a 2oz. bottle (enough to do one car). :cheers:
Old Mar 19, 2003 | 10:51 PM
92LT1Roadster's Avatar
92LT1Roadster
All these answers are good! I chose a silicone based product. Did not totally soak in :lol: My windows had a slight film where the weatherstipping touched the glass. I like the GM 2 oz tube Idea. :thumbs:
To weather stripping maintenance
