Refurbishing Interior Door Panels
Old Mar 19, 2003 | 06:03 PM
merplastic91's Avatar
merplastic91
Default Refurbishing Interior Door Panels
Help, I'm trying to save my interior door panel on the passenger side. I'm considering using some sort of ABS adhesive with some sort of band aid like patches to strengthen the door and give me places to screw the panel back on. Any suggestions on what I could use for adhesive and patches or am i going down the wrong road. Can't afford new panels so thats not an option.
Old Mar 19, 2003 | 06:13 PM
RamjetVette's Avatar
RamjetVette
Default Re: Refurbishing Interior Door Panels (merplastic87)
I had a small break in my panel and I epoxyed a small piece of thin aluminum to the back side. I picked it up at Home Depot. I used the 2 part epoxy and it is holding up very well. Good luck!
:seeya
Old Mar 19, 2003 | 06:59 PM
arbee's Avatar
arbee
You might want to try a resin and fibreglass cloth path/reinforcement.
Old Mar 20, 2003 | 06:26 AM
merplastic91
Default Re: Refurbishing Interior Door Panels (arbee)
thanks very much, 2 part expoxy with aluminum sounds like a good place to start. thanks everyone for the help
Old Mar 20, 2003 | 08:05 AM
LD85's Avatar
LD85
My method worked excellent too.
I used fiberglass sheet and BONDO to stiffen the inside ridge where mine had cracked. I just laid down the fiberglass sheet that comes with the BONDO repair kit, then applied BONDO putty with the hardender and it has never yield in 5 years!
Be advised, you may smell the bondo for a week or two after that but it was no big deal.
Old Mar 23, 2003 | 06:12 PM
merplastic91
Default Re: Refurbishing Interior Door Panels (ld85)
thanks for the great suggestions. i'm going to do a bit of work with bondo, expoxy and metal. the door really needs alot of structure so i think this should do it . i'll let you know how it comes out. i purchased new hardware from Ecklers so i'm hoping for a good result. wish me luck i'm starting now :lurk:
Old Mar 23, 2003 | 06:34 PM
LD85's Avatar
LD85
Good luck with whatever method you choose!
FTI,the BONDO sets up like a rock when its done!
To Refurbishing Interior Door Panels
