NEED SOME ADVICE ON CHANGING ROTORS
vr,
volt
You need to remove the brackets holding the calipers and then the rotors will simply slide off,.
When reattaching the caliper brackets, check the torgue specs on the bolts, On my 88 it is 137 ft lbs.
Jack
By | 2026-06-03 10:34:17
By | 2026-06-03 10:21:50
By | 2026-06-03 15:43:40
By | 2026-05-28 09:31:39
By | 2026-05-27 17:20:09
By | 2026-05-27 16:54:53
By | 2026-04-03 00:00:00
By | 2026-05-20 07:23:03
By | 2026-05-12 16:54:12
By | 2026-05-11 09:50:51
