Check engine light
Old Mar 20, 2003 | 03:01 PM
EBrown's Avatar
EBrown
Default Check engine light
I just removed and replaced the throttle body and changed the IAC valve, now the check engine light is on, is there a way to clear it. Or is there something I forgot to do. Thanks :bb
Old Mar 20, 2003 | 03:41 PM
ittlfly's Avatar
ittlfly
Default Re: Check engine light (EBrown)
Be sure to recheck that all the electrical connectors are in place and tight. Then disconnect the battery for 10 minutes. That should clear any codes. If the check engine light comes back on when you reconnect, you'll have to pull the codes to see what's up.
