Programming (tip in stumble)
Old Mar 20, 2003 | 03:37 PM
ANTI VENOM's Avatar
ANTI VENOM
Default Programming (tip in stumble)
I am still perfecting the chip in my 92. This engine is modified with all the basics. (cam,heads,headers) I still have a little stumble when I try to take off from a stand still. This only happens with mild throttle application. I don't notice it while driving around. I think I need to increase the "accelerator pump shot". Using tuner cat do I increase the ACCEL ENRICH VS DIFFERENTIAL TPS (MULT)? Is this the "pump shot"?
Old Mar 21, 2003 | 12:42 AM
drive it's Avatar
drive it
Default Re: Programming (ANTI VENOM)
I have 8D version AE-it's called accell enrich delta tps multiplier vs. delta tps. What version tdf are you using? Also if you can wide band it, you'll see right away what it needs. Yes I can't live without my wide band now! :D
Old Mar 21, 2003 | 10:50 PM
ANTI VENOM's Avatar
ANTI VENOM
Default Re: Programming (drive it)
I am using the DA2, in tuner cat.
To Programming (tip in stumble)
