Always lean and in open loop??
Old Mar 21, 2003 | 04:05 PM
sturtzy85L98's Avatar
sturtzy85L98
Default Re: NEED HELP!!!!!!!!!!!!1 (1_piece_at_a_time)
Revving the motor, I can get the o2 reading to go to 460mv and then it drops right back down to 456mv. Always the same with no jumping?????????
I grounded the ecm side of the sensor and with the car off, key on, it reads 443mv grounded and not grounded. Now I am gonna start chasing wires.
Thanks guys
Sturtzy
Old Mar 21, 2003 | 04:27 PM
sturtzy85L98
Default Re: NEED HELP!!!!!!!!!!!!1 (sturtzy85L98)
I followed the procedure in my shop manual, grounding the ECM side and going to field service mode. When I start the car I still get 456mv with the o2 sensor unhooked and grounded.
Apparantly the ECM is getting no info from the sensor.
Sturtzy
Old Mar 21, 2003 | 07:27 PM
sturtzy85L98
Problem solved. Found 3 wires that needed grounded and now the car runs great.
Thanks for the advice everyone. Saved me alot of cash.
Sturtzy
Old Mar 22, 2003 | 03:50 PM
Gregory VanLare's Avatar
Gregory VanLare
What were the three wires you found ungrounded?? I'm encountering the same problem!
