Plug wire routing LT-1
Old Mar 21, 2003 | 11:30 AM
Strick's Avatar
Strick
Default Plug wire routing LT-1
I've had my opti-spark out so long that I forgot which cylinders get the straight plug boots. It seems that #6 and #8 would not be the ones because the straight boots cause the wires to rub against the frame and fuel lines, but I thought that's where they were. The mind is a terrible thing to lose.
Strick :confused: :flag :flag :flag
Old Mar 21, 2003 | 03:13 PM
Strick's Avatar
Strick
Default Re: Plug wire routing LT-1 (Strick)
Doesn't anybody know? All you have to do is pop the hood and look. PLEASE
:flag :flag :flag
Old Mar 21, 2003 | 03:26 PM
tdock's Avatar
tdock
Ding, Ding, Ding,
6 & 8 are correct.... we have a winner.
Closest to the passenger seat.
[Modified by tdock, 2:28 PM 3/21/2003]
Old Mar 21, 2003 | 03:31 PM
Strick's Avatar
Strick
Default Re: Plug wire routing LT-1 (tdock)
Ding, Ding, Ding,
Thanks for the come back, Do your 6 & 8 wires rub on the frame or fuel lines?
:cheers: :cheers:
Old Mar 21, 2003 | 03:40 PM
tdock's Avatar
tdock
No rubbing, there is a plastic case right there next to 6 & 8, tight access, makes them difficult to get to, part of the AC system or the heater core/blower door maybe. They are straight plugs because a sensor for the coolant sits right in between them, making it tough for a 90 degree plug. The MSD wire set had all 90 boots (talking LT4 application but I'm pretty sure it's the same as LT1) But because the boots were longer they still fit.
To Plug wire routing LT-1
