85 Corvette vibrates at 80MPH
Old Mar 22, 2003 | 09:39 AM
roadwarrior's Avatar
roadwarrior
Default 85 Corvette vibrates at 80MPH
I check tires there balanced,rotors or starait shocks are new.
anyone have a clue or a suggestion let me know. :flag
Old Mar 22, 2003 | 10:33 AM
Bluevette85's Avatar
Bluevette85
Default Re: 85 Corvette vibrates at 80MPH (roadwarrior)
Things to check: alignment, upper and lower ball joints, control arm bushings could be worn and loose.
Old Mar 22, 2003 | 11:37 AM
LD85's Avatar
LD85
Default Re: 85 Corvette vibrates at 80MPH (Bluevette85)
Check damper maybe? Mine on my 85 separated and only made vibes at higer speeds.
Old Mar 22, 2003 | 01:16 PM
devilfish's Avatar
devilfish
Default Re: 85 Corvette vibrates at 80MPH (ld85)
Does it follow rpm, or just speed?
Regards
Old Mar 22, 2003 | 04:08 PM
Togo's Avatar
Togo
check shocks too if they are not working properly, they could have the wheel hopping all over the road!
Old Mar 22, 2003 | 04:26 PM
8686corvette's Avatar
8686corvette
Sounds like the alignment or the upper or lower control arm bushings. Had the same problem and had to replace them. Made a big difference :smash:
Old Mar 23, 2003 | 12:24 AM
Blueyednd's Avatar
Blueyednd
St. Jude Donor '05
Mine did the same thing at 80. I had no problems, smooth as glass at 55-60, but at 80 bad vibration. I had them re-balance and spin the tire up to a higher speed. The shop told me that all the computer stuff that balances the tire is usually set to balance them at 55-60. After mine were re-balanced (also had them put the tire weights on the inside), I have no vibration at 80, 90, etc...
Old Mar 23, 2003 | 01:24 AM
vader86's Avatar
vader86
run a search, this has come up at least 100 times
Old Mar 23, 2003 | 09:14 PM
want2drivemy85's Avatar
want2drivemy85
You might also want to consider what condition your tires are in. are they old, dry rotted, been sitting in one position for long periods of time? if so, you may need to look for new ones.
[Modified by want2drivemy85, 8:16 PM 3/23/2003]
Old Mar 23, 2003 | 09:32 PM
Strick's Avatar
Strick
I had the same type of vibration. My tires (the originals) had 40k on them! (The car was never driven hard). I bought new rims and tires, had them balanced with that new balancer that simulates the road with a roller bar against the tire while spinning. Wow, talk about smooooooth all the way to _ _ _. Also, watch out for the dreaded "flat spots" after a long sit in the garage.
Strick :flag :flag :flag
Old Mar 24, 2003 | 01:07 AM
BadDriver's Avatar
BadDriver
Default Re: 85 Corvette vibrates at 80MPH (Strick)
Mine vibrates at 130 mph,
which is a bit unnerving...
Old Mar 24, 2003 | 12:43 PM
Strick's Avatar
Strick
Default Re: 85 Corvette vibrates at 80MPH (BadDriver)
Are you sure it's the Vette vibrating or could it be your nerves? :skep: :lolg:
To 85 Corvette vibrates at 80MPH
