Has anyone done this venting of the opti
If so where did you get the 3/16 tees and the 7/32 y
question what holds the tee and y in the cap and distributor and when you put the cap back together is gasket provided adequate or should you use some sealant .If so what type.
That is what I used on my 92 opti the 95/96 cap is a direct fit , a lot easier than trying to modify old style. Corvette fever magazine has a tech section that shows venting old style cap to vented style hope this helps. :cheers:
