Buying an optispark
Old Mar 23, 2003 | 04:18 AM
540 vette's Avatar
540 vette
Default Buying an optispark
When buying an optispark from GM does it come ready to go or are there other stuff to buy.Does it come with thwe cap and rotor?I'm going to order one on Monday and was just wondering.
Old Mar 23, 2003 | 09:30 AM
kittmaster's Avatar
kittmaster
Default Re: Buying an optispark (540 vette)
The optispark IS the cap and rotor, It connects to the cam shaft and uses that to time the car properly to ignite the spark for the plugs. Don't forget to replace the wires at the same time. This is a job you DO NOT want to revisit soon. You can try the new design by dynatech engineering or make sure you go to Jeff kopp to get a GM version, and consider updating to at VENTED design to ensure longer life.
Kitt
Old Mar 23, 2003 | 06:46 PM
540 vette's Avatar
540 vette
Default Re: Buying an optispark (kittmaster)
The reason Iam asking is I called Auto Zone for a price and it was 150 for the optispark and like 210 for the cap and rotor kit.I just wanted to make sure when I spend my 330 from GM it will also have a cap and rotor.
Old Mar 23, 2003 | 06:59 PM
kittmaster's Avatar
kittmaster
NOOOOOO......never buy and optispark from autozone, if you've read anything on this forum almost all results with this component should be FACTORY GM only or the new dynatech engineering upgrade. The few bucks your gonna save may end up costing you even more money down the road not to mention the pain in the a_s_s it is to install it. If they told you that you need a cap and rotor even with an opti then they are misinformed, on top of that, imagine the quality of the product. Do yourself a favor and buy from Jeff Kopp who is a GM DEALER and I think the opti is around the same price. Tell him your a forum member, his number is 1-800-728-8267. Good luck, trust me it will be worth your time to do it this way.......others will say the same
Kitt
Old Mar 23, 2003 | 07:15 PM
POS's LT4's Avatar
POS's LT4
Autozone not only has low quality parts, but their counterpeople seem to be generally inexperienced. I stick to NAPA or GM.
Old Mar 23, 2003 | 07:36 PM
Strick's Avatar
Strick
I think you said a 95 Vette. If so, you are already vented. I totally agree with not buying an Auto Zone or any other auto parts store Opti-spark. I did the GM dealer route. Again, you don't want to do this everytime you change plugs. When you get it, you might even put a little high temp RTV around the cap/base seal especially around the connector plug. What's wrong with your current opti-spark? How many miles on it? Vented opti's usually last allot longer.
Strick :flag :flag :flag
Old Mar 23, 2003 | 08:52 PM
540 vette's Avatar
540 vette
Default Re: Buying an optispark (Strick)
I only called Auto Zone for a price.I was just curious how much they got for it.I only put GM parts in my Vette.I would never put an Auto Zone one in.Please don't throw me off the forum for it........
Old Mar 23, 2003 | 09:47 PM
kittmaster's Avatar
kittmaster
:lolg: :lolg: :lolg: :lolg: :lolg: :lolg: :lolg: :lolg: :lolg: :lolg:
We'll let it slide this time...................but don't let us catch you.... :jester ....... :thumbs:
Kitt
Old Mar 24, 2003 | 12:42 PM
John Row's Avatar
John Row
Whether you get the opti from GM or NAPA, be sure to split it open and give it a nice seal of hi-temp RTV. The 95 has the better seals, but they still get brittle, shrink and crack over time.
Old Mar 24, 2003 | 01:05 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
I just orderd mine last night from the last deal corvette but I don't have the link here at work it's something like ldcorvette.com not to bad $370.00 for the whole thing...
Found it... http://tld-corvette.com/
[Modified by fsr402, 1:47 PM 3/24/2003]
Old Mar 24, 2003 | 04:22 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Buying an optispark (fsr402)
The '92-94 are more expensive than the later '95-96 versions. For one of the best deals you can get, give Jeff Kopp a call 800-728-8267 (ask for him and let him know you are a Forum member). Last time I got one it was around $260 for the '95-96 model as far as my memory lets me remember.
To Buying an optispark
