Shift kit installed, now NO Reverse!!
Old Mar 23, 2003 | 09:23 AM
Cratzy's Avatar
Cratzy
Default Shift kit installed, now NO Reverse!!
Despite that you told me not to go with the B&M shift kit but install the TransGo instead, I did install the B&M poopie kit in my TH700R4.
I followed the instructions included with the kit. I had to use some grease on the checkballs to get them to stay in place while I put everything together again. It was written in the instructions that you could use some grease to make the checkballs stay in place.
I also adjusted the T.V cable according to the istructions.
Now, when I started her up to take her on a test drive I couldn't get the reverse to work. I couldn't get out of the garage!!! :mad
My teori was that the grease that I used on the checkballs made them stick and prevented the oil to go the right direction. But I don't know anything about transmissions... :confused:
I thought that if I just got the transmission oil warm it would make the grease go away and the problems aswell. I checked the oil level after she was warm and it was okay. Nothing happened, still no reverse!
I put the stick in reverse and I revved her up to about 3000-3500rpm, then she started to move, slowely. Just enough to get out of the garage. I took her for a long drive. Shifted through all gears. But I couldn't get the reverse to work.
I also discovered that the shifts from 1-2 was at about 4000rpm. Before I installed the kit it would change gears at about 5500-6000rpm. The 1-2 shift is much firmer though.
What can be wrong? T.v cable? Checkballs? Anything that might have got lost during the assemble? Don't tell me that I should have istalled Transgo instead :smash:
Thanks in advance :cheers:
Old Mar 23, 2003 | 10:18 AM
Bluevette85's Avatar
Bluevette85
Default Re: Shift kit installed, now NO Reverse!! (Cratzy)
I used vasoline to hold the check ***** in place. It dissolves quickly with transmission fluid.
Old Mar 23, 2003 | 10:23 AM
NHVett's Avatar
NHVett
Cruise-In I Veteran
Cruise-In II Veteran
Keep trying -gently- . Quite often a piece of lint, hair, or an air bubble will interfere with normal valve and check ball function. Over a period of time, usually short, these conditions rectify themselves..
[Modified by NHVett, 10:23 AM 3/23/2003]
Old Mar 23, 2003 | 10:32 AM
Cratzy's Avatar
Cratzy
Default Re: Shift kit installed, now NO Reverse!! (NHVett)
So you think my theory with the checkballs is correct then?
I am afraid that I will destroy somthing when I try to get it going. Like burning something in the transmission?
:cheers:
Old Mar 23, 2003 | 01:31 PM
Fartleker's Avatar
Fartleker
how hard was it to install the shift kit? ive got a transgo that needs to be done. seems like an entire weekends project...
Old Mar 23, 2003 | 01:41 PM
Cratzy's Avatar
Cratzy
Default Re: Shift kit installed, now NO Reverse!! (UA89Vette)
It took me all weekend, but I am sure it can be done much faster. Worse thing was all the hydraulic oil that is coming from everywhere...
Other than that it was a mess and that I lost the reverse it was ok. :smash:
Old Mar 23, 2003 | 02:33 PM
devilfish's Avatar
devilfish
äsh back e fegt..
Strange thing, any uppdates?
Tjena
Old Mar 24, 2003 | 05:05 AM
Cratzy's Avatar
Cratzy
Default Re: Shift kit installed, now NO Reverse!! (devilfish)
OK, it is more racing without the reverse, look at F1 :D
But it is very convenient to have a reverse gear...
No updates yet. I haven’t been out to the garage. I have to gather some strength first.
Someone told me that it might be the pressure regulator valve. If it is installed wrong it will result in malfunctions of the reverse gear. Comments on that?
:cheers:
Old Mar 24, 2003 | 11:45 PM
Nitro Junkie's Avatar
Nitro Junkie
I had the same problem, and worse. First time I didn't seat the pressure regulaator snap-ring correctly. When I started it, it blew the regulator into the bottom of the pan. Disassembled. reassemble. Now no reverse. I had forgotten to torque the bolts on the block-off plate. Forward was OK, but it released the pressure in reverse. Disassemble, reassemble.
Third times the charm.
Old Mar 24, 2003 | 11:49 PM
scorp508's Avatar
scorp508
Default Re: Shift kit installed, now NO Reverse!! (Nitro Junkie)
Cut the wheel full lock and mash the gas. There ya go, you are now reversed. :D
Old Mar 25, 2003 | 05:17 AM
Cratzy's Avatar
Cratzy
How can you tell right from wrong when you istalling the snap-ring? I had some troubles with mine and I don't know if I got it right.
Or I can just do what Scorp told me to... :D
:cheers:
Old Mar 25, 2003 | 07:19 AM
Vic'89's Avatar
Vic'89
Just my opinion , but I would let a Tranny expert install a shift kit.
If it messes up, let them be responsible for it.
Vic
Old Mar 25, 2003 | 09:51 PM
Alex D's Avatar
Alex D
Default Re: Shift kit installed, now NO Reverse!! (Vic'89)
I had a no reverse situation after installing a B&M kit once.......the check ball was in the wrong location.......do not use grease to hold them, ONLY petroleum jelly......the 4500 rpm shift point (lower shift points) is typical for a "drill-the-separator-plate" shift kit........
Old Mar 26, 2003 | 06:36 AM
Cratzy's Avatar
Cratzy
Default Re: Shift kit installed, now NO Reverse!! (Alex D)
I suspect the grease aswell. I guess I will have to tear it apart again and clean all the grease away.
What about the 4500 rpm shift point, is there something I can do to get it back to normal, 5500-6000 rpm shift point? The car now feels slower then before I installed the shift kit.
:cheers:
To Shift kit installed, now NO Reverse!!
