2.02" Valve Clearance Question
Old Mar 24, 2003 | 04:12 PM
Five Window's Avatar
Five Window
Default 2.02" Valve Clearance Question
I'm installing a pair of Edelbrock heads with 2.02" intakes on my '86 along with a roller cam with .510" lift. Will there be any problem with piston-to- valve clearance with the larger intakes on these heads?
How much lift can you get away with with stock pistons?
Old Mar 24, 2003 | 04:40 PM
scorp508's Avatar
scorp508
Shouldn't be any issues. I'm running .560" lift with 2.02" valves and have the same pistons as you (assuming yours are stock).
Old Mar 25, 2003 | 07:04 AM
Five Window
Default Re: (scorp508)
Thanks!
Old Mar 25, 2003 | 01:12 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: 2.02" Valve Clearance Question (Five Window)
Shouldn't be an issue with intake valve as the piston is down when it's full open.
To 2.02" Valve Clearance Question
