Thje ecm will get hot=normal. What scan tool? Also I've found that aldl plugs that have had the paperclip inserted more than a few times to pull codes will have the wire clips in them kinda' stretched out and will give fail to establish comm. Could try to squeeze the clips back together....
I have two OTC Monitor 2000's... and it's been like that since i got the car. Should i use a pin or something and try to get the ALDL pins crunched together again?
i'll try to ask this question here, maybe i'll get an answer. this code reading thing, i dont get it. is this something i have to buy? and where to i hook it up to my car? and how do i use it? can my car be doing something bad and me not know it and the only way i can tell it is from one of theses? i need the full run on all this junk please. anyone who knows what their doing with all this electronic stuff. :crazy:
If your scanner is adaptable to different cars, assure that it's set up for your year and car. Sometimes I have my AutoXray setup for the '86 IROC and it doesn't want to talk to the '88 Vette till I set it up correctly.
A scan tool is useful in pulling trouble codes on an OBD-I system and it provides data on all sensors that the ECM can see. It is useful for tuning as well as diagnostic work. It just plugs into the ALDL connector under the left hush pannel.
That sounds like it might be what's happening.. the only settings the Monitor has is baud rate and stop bits.. does anyone know what the baud rate is? I know this scanner always worked fine on my 88 iroc and 89 gta..
