emission control canister purge code from scan tool?
Old Mar 25, 2003 | 11:30 AM
jwlowtheman's Avatar
jwlowtheman
Default emission control canister purge code from scan tool?
I got a code on scan tool that says purge emission control canister, where is the emssion control canister on LT4 any one know? or has anyone had this problem
Old Mar 25, 2003 | 11:45 AM
John Row's Avatar
John Row
Default Re: emission control canister purge code from scan tool? (jwlowtheman)
The canister is behind the right rear tire.
There was a thread sometime in the past few months about this. Try searching the archives. As I remember it was pretty well detailed. It should have been turned into a Tech Tip.
Old Mar 25, 2003 | 11:52 AM
tdock's Avatar
tdock
there are three components to the canister purge system, the canister which is located behind the passenger's side rear tire/quarter panel, above a triangular panel. The canister is connected via a vacuum hose up to a check valve on the passenger side of the intake (under the panel near the throttle body) which connects to a solenoid about 8 inches back near the middle of the intake, which connects/purges into the throttle body. Make sure the electrial connector is on the solenoid and all the vacuum hoses are connected. If the electrical connector is not connected it will throw the code.
[Modified by tdock, 10:54 AM 3/25/2003]
To emission control canister purge code from scan tool?
