TPS Voltage
Old Mar 25, 2003 | 09:27 PM
91superram's Avatar
91superram
Default TPS Voltage
I find that when I set my TPS to a lower voltage(.41v) I get a better
performance and a cleaner idle (not so rich). Can this cause any problems with my pcm settings.Chip was programed by TPIS. Do I have to send it back
for reprograming or can I leave it as is.
1991 mods are 350,superram,edelbrock performer heads,2033 crane cam,
24lbs injectors 1.6rockers
[Modified by 91superram, 2:29 AM 3/26/2003]
Old Mar 25, 2003 | 09:38 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: TPS Voltage (91superram)
If it idles better, doesn't throw a code and pulls the same power, don't fix it.
Old Mar 25, 2003 | 10:01 PM
91superram's Avatar
91superram
Default Re: TPS Voltage (65Z01)
Thanks 65Z01
Do you know what the operating voltage range is
[Modified by 91superram, 3:03 AM 3/26/2003]
To TPS Voltage
