another member checking in here :D
What if every single SR owner/forum member posted to this thread or posted in "all SR owners check in" thread? Every one check in? :grouphug: :D
I noticed that you have a ACCEL Super Ram Manifold on your 88. Did you have any problems with installation or quality of this unit? If so what were your problems. Did the performance of the car increase? I would appreciate any help you can provide. :flag
Not sure if your directing that question at me but I'll answer anyway. You'll need a couple special small wrenches that probably aren't in your toolbox but that can be picked-up at Sears. I had to grind the inner edge of the valve covers to clear the runners. Otherwise it's pretty straight forward. I took my time and posted questions here on the forum when I got stuck.
As far as performance, SOTP performance, the car is pulling more. I will have track results on 4/9. Others can give you before/after results.
Chuck looking though your web site and saw that you have a wheel skin cover. How do you like it? Any sliping?
No Rich, Grips just fine. It took me about an hour to install. By the time your finished however, your fingers fell like they went through a meat grinder
MrNuke is an official member. I just saw the car in OPERATIONAL form!! Sounded damn good to(He still has to tinker with a few things, but it's up and running!) :cheers:
