Dead Battery Question ??
Old Mar 27, 2003 | 09:20 AM
corvette-pilot's Avatar
corvette-pilot
Default Dead Battery Question ??
I was excited to get home yesturday with the good weather and pull out my baby for the first time.
DEAD Battery :mad
I just bought it in October, new Exide.
I pulled the neg cable, car stored in my garage, non-heated but stayed 35F or higher, never tried to start it.
Should it have gone so dead I didn't even have dome lights?
How long did your battery last ?
I knoiw next winter I will get one of those trickle chargers.
Old Mar 27, 2003 | 09:25 AM
sumoboy's Avatar
sumoboy
Default Re: Dead Battery Question ?? (corvette-pilot)
If you stored it since October and never started it then you need to trickle charge the battery for at least 24hrs minimum. :thumbs:
Old Mar 27, 2003 | 09:38 AM
don hall's Avatar
don hall
How long do batteries last ?..
A quality battery can last 10 years or more, if properly maintained. Maintain a full charge at all times for best results.
Invest in a battery charger that has multiple amperage settings: 2 - 10 - 60, with automatic shut-off.
Old Mar 27, 2003 | 12:25 PM
corvette-pilot
Default Re: Dead Battery Question ?? (Oldman)
I'm headed to Sears right after work :thumbs:
I just figured it would have stayed a little charged over the winter with no load?
Old Mar 27, 2003 | 12:33 PM
jfb's Avatar
jfb
I have posted this info on lead acid batteries many many times. Lets do it again. Lead acid batteries self discharge about 1% every day even if disconnected. Lead acid batteries do not like sitting for long periods doing nothing and the plates collect lead sulphate which is a good insulator which turns the battery into a door stop. If you store your car for longer than 4 weeks, I recommend you use an automatic battery charger that turns itself off when the battery is charged. If you already have a battery charger, then buy an interval timer and have it turn your charger on for its minimum interval each day (usually 15 min) and this will keep your battery charged and in good condition.
Old Mar 27, 2003 | 02:09 PM
corvette-pilot
Default Re: Dead Battery Question ?? (jfb)
Great idea using an outlet timer !
I happen to have a couple that I have no use for until now
Thanks for the tip
:flag :flag :flag :flag :flag
Old Mar 27, 2003 | 04:19 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Cruise-In II Veteran
Currently Corvette-less
I also have an Exide Battery in my 92 Coupe. After a few intervals that extended for a period of greater than 4 weeks with no activity ~ My battery bit the dust. The battery was 2 years old at the time.
I agree with jfb that innactivity without periodic charge will eventually turn your battery into a doorstop. The Manager at the local Checker Auto didn't give me any grief. He adjusted the price and sent me on my way.
I would also like to add that making a carte-blanc statement that a battery should last 5 to 7 years doesn't always hold true. The extreme heat here in Phoenix makes it near impossible to get more than 2 years life out of the best of batteries.
~ Purp :yesnod:
[Modified by PurpleC4, 2:20 PM 3/27/2003]
Old Mar 27, 2003 | 06:33 PM
GDB's Avatar
GDB
Hi corvette-pilot, really a somewhat difficult question. But on a daily driver the battery should last 3 years or longer depending on your climate and the quality of battery. However when in storage and even with the cable disconnected, then this is not considered really a normal condition. So longevity is hard to answer. But...why not take it back to where you bought it and exchange it? I had a similar thing happen to me and the battery had a 4 year full replacement which I took advantage of.
Old Mar 27, 2003 | 06:40 PM
JDANNER's Avatar
JDANNER
Every car that I've bedded down for the winter months have their batteries die. I've come to the conclusion that I'll buy a cheap battery every couple of years because cheap or expensive they will die at the same rate. As it starts to get warmer I will charge it for a day and I'm good for the summer. That's my 2cents.
To Dead Battery Question ??
