LT1 MAF question
Old Mar 28, 2003 | 08:35 AM
The Rex's Avatar
The Rex
Default LT1 MAF question
My friend has a 96 LT1. The car has been running very poor & dying when throttled. When the MAF sensor is unplugged, it smoothes right out. He doesn't have a scan tool, but all signs are pointing to a bad MAF. He said a new on from the Chevy house is around $400. :eek: Any better suggestions?
Old Mar 28, 2003 | 09:14 AM
Zix's Avatar
Zix
Default Re: LT1 MAF question (96 LTRex-4)
Take the MAF out and take a look at it, see if it is gummed up at all (usually fron K&N Filter oil) or see if one of the fragile little wires is broken. If it looks visibly OK see if you can get a local Chevy shop to test it. If it does come back bad then I would recommend you go to Jeff Kopp to get a better price on a replacement
Old Mar 28, 2003 | 10:45 AM
95Redsled's Avatar
95Redsled
Check out Ebay, they have plenty of Granitelli MAFs for LT1s for less than $300. It may or may not live up to HP claims, but it is IMO a better option to a stock one. BTW it is also about 2lbs lighter. Good luck. :chevy
Old Mar 28, 2003 | 11:20 AM
tdock's Avatar
tdock
New MAF from Jeff Kopp was around $220. Just a heads up, I had the same symptoms, would be idling all over the place, disconnect the MAF and it would smooth right out, so I replaced it with a new one. Didn't fix it (argh, &%@@#$%) Still trying to figure it out.
Old Mar 29, 2003 | 09:20 AM
silver & red CE's Avatar
silver & red CE
Default Re: LT1 MAF question (tdock)
...disconnect the MAF and it would smooth right out, so I replaced it with a new one. Didn't fix it (argh, &%@@#$%) Still trying to figure it out.
That is a hint though, when you pull the MAF the PCM goes to speed density mode. Wonder if it's a bad O2 sensor(s), how old are they?
Eric
To LT1 MAF question
